Results 1 to 10 of 29
Thread: CCR2006 removal help!!!!!
    Regular Member korlinski's Avatar
    South
    Angry CCR2006 removal help!!!!!
    Hi all,
    I am trying to remove my CCr2006 head unit.
    I have removed the little nuts with an hex key.
    I have a set of double din head unit removal keys.
    I have push them in....
    And on pulling, the keys pull out!!!
    HELP!!!
    what am I doing wrong!!
    Nicking Ya Dinner.
    You're not, unfortunately the cradle and the radio have a habit of welding themselves together, I think if it wont budge you have two options, one is to break the radio with brute force, and the other is to take the dash apart and see if you can separate the two
    Feb 2007
    Kent
    Have you tried exerting a little outward force on the pins at the same time as pulling back?
    South
    Quote Originally Posted by Pingu71 View Post
    I have tired little outward little inward force. Riggleing, Jiggling. Praying,
    anyone in the farnbrrough area taken a head unit out who could lend a hand?
    Regular Member rich32's Avatar
    Feb 2007
    sheffield
    i got a driver down the side and leaverd at the same time but pulled the front off
    Regular Member danlat1415's Avatar
    Lancashire
    Are you using the removal pins for Vauxhall cars? if it's slighty wrong size, it won't budge the catches at the sides on radio and release it.
    Have you tried pulling out the botton shelf thing just above the cigerette lighter, then pull out and unplug the climate controls. This way you can get underneath the stereo and try that way?
    South
    Quote Originally Posted by danlat1415 View Post
    I purchased a set of double din (vauxhall) stereo removal keys from Halfrauds.
    They didnt perfectly fit and needed i tiny bit of bending for them to fit. I have had the climate control out and the screen above the stereo out.
    Does anyone have a set of Vauxhall removal keys that they have used and know work? If so could I "borrow" or buy them??
    Will the dealer be able to remove the stereo?
    Regular Member evsy72's Avatar
    south wales
    You will need someone to help but this is how i got mine out. Took the heater pannel out below reach in push stereo from behind while pulling with the keys from the front.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    You can get to the back of the sterio by taking the glove box out or the easeist way is to put bluetak on the blanking switches and pull them out, you can then put your fingers behind sterio facia and pull it out.HTH
    South
    OK
    I dont know if the keys are working. I put them in and I have tried pulling from under the heater, and i have tried from the side.
    How can I tell if the clips are naff? I am thinking of taking them back to halfrauds and asking them to have a go?
  1. CCR2006 cage removal - help please!!!
    By robster23 in forum Electrical & ICE (including SatNav)
    Last Post: 10th August 2008, 18:52
  2. Ccr2006
    By Elevonic in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2007, 18:53
  3. ccr2006
    By stuart fraser in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2007, 16:12
