Results 1 to 10 of 21
Thread: I'm picking up good vibrations......not
    May 2007
    Scotland
    confused I'm picking up good vibrations......not
    Okay peeps
    Thinking caps on. Just spent last 30 mins doing a 'vibration' search. Here's my problem. Any kind of a load on the engine causes a vibration through the cabin and steering wheel at any speed. Ruled out wheels as deperessing the clutch 'cures' the problem. It happens at any revs but particularly bad at around 3500 which must be resonant frequency of the car. Local dealer checked obvious, engine mountings, exhaust etc. Looking at engine and transmission but I'm thinking transmission as engine sounds fine at idle and when depressing clutch at speed. Local dealer has little experience of 2.2 engines so is a bit lost. Only similar problem i found on the search was Boris with a flywheel.
    2002 2.2 SRI
    Any thoughts out there.
    MOTM
    Mileage : 000
    Have you checked the brake calipers, one of them might be sticking and the pad is not moving off the disc far enough, if you drive the car for a while then stop and carefully feel the front wheels to see if there is any difference in tempreture, if one is very noticably hotter then you might have a caliper sticking. I had this happen on a car I had many years back.
    May 2007
    Scotland
    Hi Ed
    I don't think it's anything related to the wheels and brakes. As I said the vibration stops when I disengage the engine from the wheels at speed. I imagine if it was a sticking caliper then the vibration would continue.
    Thanks for your thoughts.
    MOTM
    Regular Member stickshift's Avatar
    North London
    Is it a 2.2 petrol? If so could be some thing to do with the counter balance shafts or dual mass fly wheel
    May 2007
    Scotland
    Thanks for that Stickshift
    What the f*** is a counter balance shaft when it's at home and are they prone to causing a whole lotta shakin'?
    MOTM
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Didn't know the 2.2 petrol had a dual mass fly, thought that was just for the diesel's.
    May 2007
    Scotland
    Okay men
    Let's keep this in English (or Scottish)
    Now what is a dual mass fly ?? and can it cause the shakes??
    MOTM
    North London
    Not heard of any probs with them but they are there to make the engine smoother, it's something GM picked up from Saab when they bought them in the early 90's. They are chain driven off the crank pully and look like two small cam shafts located in the main block. Look up file No. 00301314 in the link below. It's not a Vectra but its the same engine.
    http://www.speedsterclub.nl/biblioth...%20Aggregates/
    May 2007
    Scotland
    Cheers Stickshift
    Thanks for the link.
    MOTM
    North London
  1. vibrations
    By tiimi in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2012, 17:55
  2. Bad vibrations
    By tony tyre 1 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th November 2011, 07:25
  3. Vibrations?
    By Exclusive BV in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2011, 15:40
  4. good vibrations
    By chief29 in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2009, 23:05
  5. Vibrations!!
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2008, 11:39
