Thread: HELP needed guys!!!!
    Regular Member lochgilp's Avatar
    argyll
    Default HELP needed guys!!!!
    im hoping you good folks can help me out?
    My car a 2005 sri cdti (150) has been cutting out the last few days it seems to be when i change down into 2nd or 3rd and it wont start again but after you leave the car and lock it and come back in 5mins it starts ok, but today it has happened 3 times so i thought it might be the tuning box that i have been running for over a year(powerclick green) so once i eventually made it home today i removed the tuning box now the stability light and engine lights are on in the dash and is idling at 1500 revs and the accelerater pedel does nothing??????
    Any ideas or is there a special way of removing the tuning box
    thanks as always in advance
    Scott
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Try disconnecting the battery for about 30 minutes & then try it again
    connected the plug on the fuel rail correctly when you removed the box?????
    morton
    i've noticed a few of these issues popping up where tuning boxes are fitted ! but it always seems to be a problem with the car not the box !
    leighton buzzard
    hi dont know about your first problem but when you took the tuning box off you have put the plug back upside down,i did this with mine got the same faults as you.
  1. VXR Guys, Help Needed.
    By Signum-Steve in forum Styling
    Last Post: 22nd May 2011, 13:52
  2. help needed please guys
    By adzs22 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2010, 23:08
  3. Help Needed Here Guys ;)
    By Tam80 in forum Engine & Drivetrain
    Last Post: 6th September 2010, 08:19
  4. Help Needed Please Guys.
    By PORKBALLS29 in forum Photoshop section
    Last Post: 14th May 2009, 12:13
  5. advice needed guys
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2008, 23:47
