Thread: STEREO WIRING in
    Regular Member Darrell's Avatar
    Feb 2007
    Wolverhampton
    Default STEREO WIRING in
    Got my stereo, got my wiring harness, got my aerial adaptor, got my bluetooth kit. No problems there.
    All fitted... no problems there.
    Ignition on, problem there! Had to switch the red and yellow for the perm live, knew this cos wasn't storing stations. I'm normally good with these sort of things, so i know i've got the perm live now.
    The problem is, that i don't appear to be getting a switched live anywhere! If i put red and yellow, to the red from car, works fine, so i know everything stereo-wise is working.
    But try to connect the switched live separate and i get nothing, any ideas??
    The wiring harness (adaptor thing) is all wired straight across, but the one with "+12v switched" written on it isn't, it is just approx 1 metre long and connected to nothing, does this mean i've gotta trace a switched 12v from somewhere else?
    Tried touching it on the other wires coming from cars loom, but nothing.
    PLEASE PLEASE get me out of this tricky one!
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Maybe pinch it from the ciggy lighter?
    Feb 2006
    Dorset
    Ignition is from the cig lighter , there is no ignition at the head unit , unless you want to go purchasing can bus modules
    Regular Member S888 SRB's Avatar
    May 2006
    Hemel Hempstead, Herts
    My amp remote signal cable is driven by the fag lighter
    HTH
    Feb 2007
    Wolverhampton
    is that easy to get to?
    May 2006
    Yeah the trim mostly pops out, stereo then heater controls then the cubby tray and tuck it under then bobs your mothers brother
    Feb 2007
    Wolverhampton
    all done, cheers for replies!
    May 2006
    Nice one sir
  1. Yet another stereo wiring prob
    By Ace1981 in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2012, 12:56
  2. Stereo Wiring Diagram
    By platinumpete in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2011, 16:48
  3. Need help with wiring stereo and amp
    By gibbon7000 in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2010, 14:25
  4. Help with Stereo Wiring
    By IrishWhiskeyChaser in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2010, 09:28
  5. re-wiring stereo controls
    By davidjameswest in forum General Chat
    Last Post: 10th April 2009, 22:41
re wiring a vectra c stereo
