Thread: Headlight problem.
    Regular Member JCB's Avatar
    Oh, I forgot to remember!
    Default Headlight problem.
    As some peeps may be aware already - I've had a little prob with some sri headlights I bought and fitted.
    I was very careful when fitting so pretty sure it isn't anything I've done - anyway - The drivers side main beam points, well, skyward.....and when I took a closer look the other day, the glass dome (that looks like a marble) into which the bulb sites, doesn't sit in the socket behind the plasticcover properly - is this due to something been broken or do you reckon I could wiggle it back in.....don't really want to pull the light out again - its a nightmare!
    Thanks in hadvance!
    Take the bulbs/lamps out , put your finger into the whole and pull it gently back onto the ball/socket. This happened to mine too!
    Jul 2006
    Mexico
    HA! did the same over here.....may be this will help
    http://forum.vectra-c.com/showthread.php?t=13113
    sounds just like an adjuster motor ball not seated correctly..
    Oh yeah - forgot to mention that - the light doesn't move when i fiddle with the adjuster - thought it might be that - how the F am I gonna get to it without taking the light out?????
    Guess I'll just have to have a play...
    Quote Originally Posted by Astrase20 View Post
    Look at my post, its a 5 min fix thanks to Mark!
    Jul 2006
    Mexico
    Just push back the cromed surround until it attaches the plastic rod with the round tip back in.
  1. headlight problem
    By vvcsri in forum Bodywork & Interior
    Last Post: 29th November 2010, 02:31
  2. headlight problem?
    By jungle in forum Electrical & ICE (including SatNav)
    Last Post: 19th November 2010, 23:51
  3. Self Levelling Headlight problem?
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 20:22
  4. Headlight problem
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 17:27
  5. pre-facelift headlight problem
    By the-ferret in forum Electrical & ICE (including SatNav)
    Last Post: 15th July 2008, 20:31
