Thread: Help!! Wind Deflectors & Spring Clip
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Default Help!! Wind Deflectors & Spring Clip
    Tried to fit the new wind deflectors from Germany this morning - attached the enclosed spring clip to the deflector but it kept falling off before I managed to get the deflector in place - am I useless or have others had the same problem & is there a solution?
    Larkhall
    I got the VX ones and there is a thin wing that gets pushed under the rubber rim of the window, don't know if yours are the same though
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Quote Originally Posted by Ian S100 View Post
    The way I did them was - put teh deflector in place, then put the clip on the end of a flat bladed screwdriver then push it up into the rubber - finish it off by closing the window!
    Mar 2007
    Southport
    Quote Originally Posted by Neil View Post
    Cheers that's the conclusion I was coming to but it's not what the diagram seems to show
    Mar 2007
    Southport
    Quote Originally Posted by tamf2007 View Post
    These are the German Octimex deflectors - similar principle but come with a small spring clip that is supposed to stick to the wing & get forced into the U channeling. I assume it's to stop them falling out but it doesn't stay stuck to the wing long enough to get shoved into the channel so it's follow Neil's example I think
  1. wind deflectors
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2010, 18:01
  2. wind deflectors....
    By bobby-tupper in forum Parts for sale
    Last Post: 8th December 2009, 06:56
  3. wind deflectors
    By big rich in forum Styling
    Last Post: 21st April 2009, 15:26
  4. Wind Deflectors
    Last Post: 3rd February 2009, 17:16
