Thread: Turbo oil change
    Tyneside
    Default Turbo oil change
    A question for 2.0 turbo owners, how often do you do an oil change, what do you recommend, or would you say just do it every service?
    I do an interim oil change between services so the max the oil is in for is 10,000 miles.
    Nicking Ya Dinner.
    10k, all the way, if it's low miles flush it as well, above 50k don't bother you will cause yourself problems later.
    Regular Member Karl's Avatar
    Sunderland
    I'll get shouted at again, but I would never let a turbo car go over 5k with the same oil (unless it was a company car in which case I don't care).
    When you can change oil for £25 I don't see any reason not to.
    May 2006
    Mansfield
    10k with an oil flush
    SJ
    Regular Member LAV6Y's Avatar
    Oct 2006
    Lisburn, NI
    Quote Originally Posted by VauxVeteran View Post
    Why would you cause problems later????
    'cos it would dislodge the crud that had built-up over time and end up just being moved elsewhere where it could then cause a problem - that's the theory anyway.
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Isn't engine flush designed to break down the sludge, turning it into liquid so it comes out with your oil ?
    Belfast
    Yeah, but you always end up with a load of oil in the sump after it's fully drained. Especially the lumpy bits.
  1. Oil Change 2.0 Turbo
    By Mark2.2 in forum Engine & Drivetrain
    Last Post: 4th November 2016, 17:03
  2. how to change a turbo
    By vectraedition100 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2012, 17:54
  3. Turbo Change
    By tommy1976 in forum Petrol Engine related
    Last Post: 3rd April 2011, 00:49
  4. 2.2 dti turbo change
    By luckyracer in forum Engine & Drivetrain
    Last Post: 30th May 2010, 11:25
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
