Results 1 to 10 of 11
Thread: Leaky boot on the vectra
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    Angry Leaky boot on the vectra
    is it a design floor on the vectra that the water leak into the boot when opened after raining?? As i bougths some new clothes the other day , and ended up soaking them before even wearing them......
    morton
    common fault this one is ! look on the faults forum page and it will give you loads of info on curing it and the causes of !!
    yep, it's a sad design flaw...i open a wet bootlid about 8 inches to first let the water run off before opening it right up, then the water stays in the gutters and not in the boot..
    Quote Originally Posted by veccy22 View Post
    he means by water shooting off the bootlid into the boot when you open it.. not by leaky seals mate..
    sorry should have made my self clearer
    morton
    he he ! nearly hung myself there !! i cant think as i've had that problem ? (scratches head )
    Regular Member Karl's Avatar
    Sunderland
    I have to admit, it sounds like something you removed to fit the rear parking sensors has created the problem, might be worth double checking all fittings and fixtures are correctly aligned.
    you've fell for the same way of thinking.....
    it's not a strange waterleak he's suffering.. it's how the water shoots into the boot when you open it and the glass is rain covered.....one of VXs finest design flaws..
    Quote Originally Posted by Karl View Post
    the parking sensors are factory fitted
    When the boot is lifted , the water runs of the window and instead of running down the gutters , it is running into the boot...The rubber seals are all intake.
    As suggested above the best way to stop this is to open it slightly and let the water run off before opening it fully...
    Thanks for feed back all
    Giving the rear wiper a sweep before hand helps as well, my poor dog cowers in the corner when I open it in the rain as she has learned she is in for a soakin *lol*
  1. leaky leaky leaky :(
    By bappy in forum Engine & Drivetrain
    Last Post: 12th August 2012, 13:31
  2. Leaky exhaust joint
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2009, 21:43
  3. leaky oil cap
    By peadar in forum Engine & Drivetrain
    Last Post: 13th October 2008, 08:02
