Thread: oil filter
    May 2006
    North yorkshire
    Default oil filter
    i'm going too change the oil on my cdti 150 and noticed the and filter cover has a toothed edge - why and will it cause trouble unsrewing the filter?
    also there is a small pipe underneath the filter cover with a yellow rubber cap - will oil pour out as i unscrew the filter or is to let air in to extract the filter?
    sorry if i seem dim but never encountered anything like this before.
    [Ex]Admin Duncan's Avatar
    Didn't you get the answer in your other thread?
    the filter covers edge is to help to get extra 'purchase' on it if you are using a strap wrench..but i use a socket on the end....
    and the small pipe is just designed to drop oil on your exhaust pipe....
    May 2006
    North yorkshire
    sorry, your right i should keep note of all the posts a reply to or write in order avoid this sort of thing in the future.
    Regular Member Sundance's Avatar
    Scotland
    The edge is like that because they used to have a little spring clip attached to side of filter housing which rested in the grooves on the cover, which acted like a lock to stop it from undoing. i am not sure exactly when they stopped fitting the spring but they normally fell off anyway the first time you removed the filter
    there is a tool available to stop the oil dripping on the exhaust, its a metal shield that clips on......... i personally tie a rag around the exhaust
  1. Oil filter
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 24th April 2012, 20:40
  2. Standard air filter or K&N Panel Filter
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 15:38
  3. changin oil, oil filter air filter and plugs any handy tips!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 15:04
  4. Air filter
    By Deano.56 in forum Engine & Drivetrain
    Last Post: 13th July 2009, 21:17
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
