Thread: subs
    Regular Member rich32's Avatar
    Feb 2007
    sheffield
    Default subs
    does any one know if you can repair subs ? when fitted i thought it was the cars plastics vibrating ! but to my norro its the sub . i took it out and plugged the hole and it now sounds nice and deep but of course not as loud
    Jul 2006
    Mexico
    Can´t quite understand what problem do you have mate, yo mean that the cone is damaged? Or the coil is touching the magnet?
    member of the smoke patrol 230bhp+
    some sub can be repaired """" as new """ and most can only be a quick fix job
    with the quick fix its only time befor its going to be dead dead dead
    you might get a few months out of it ..
    if you tell me what sub it is i can tell you what the bet thing is to use for the quick fix
    also were is the hole
    a pic of the damage would be good to tell the best way to fix
    Feb 2007
    sheffield
    looks perfect but when its powerd it bangs and makes horrid noises
    Feb 2007
    sheffield
    its a atomic manhatton
    Jul 2006
    Mexico
    If it´s a small hole in the cone you can apply a little of silicone to bond it together, this asumming it´s a paper cone. The other thing that can make it rattle is that the foam or rubber suroundigs of the cone are damaged, they can be relaced but it´s tricky to align perfectly the coil inside the magnet.
    Do you have a pic?
    Feb 2007
    sheffield
    there is no hole and its a celver cone
    it sounds like the sub has a damaged voice coil
    SOMERSET
    Quote Originally Posted by chrisgettings View Post
    The sub if it is blown will not move in or out properly, try gentle pushing the cone in and out and if it's a smooth action then it is fine but if it feel's rough then it is blown.
  1. Under seat coMpact subs, bass tubes and boot subs, what to get???????
    By Big Red in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2012, 18:26
  2. Help with what amp to buy with my subs anyone
    By 0114NIGEL0114 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2011, 18:47
  3. Amp & Subs
    By danny1992 in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2010, 15:38
  4. 2 subs and amp
    By CDTi-SRi-Matt in forum Parts for sale
    Last Post: 25th January 2009, 14:38
