Thread: TECH 2 Anyone?
    Regular Member Digital_kid's Avatar
    Oct 2006
    Cheshire
    Default TECH 2 Anyone?
    Hi,
    Speaking to her uncle again (Vauxhall man) when I fit my K&N Cone filter its sounds the nuts but when the engine is warm it starts pinking. I have tried the battery off etc route but no joy.
    He mentioned if I fit the K&N and hook it to the TECH2 the TECH2 will reset the values and it will learn the new values on the way home and reprogram itself.
    He has access to a TECH2 but have any of you guys based near Cheshire have access to one as he is not working for 3 weeks
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Disconnect the battery for 15-20 mins, it does the same thing. Also too much heat is sucked up by the K&N cone type, the best bet is to go for a K&N panel filter in de-restricted air box HTH.
    Regular Member Silentknight's Avatar
    Swindon
    I've just bought the K&N panel filter and am going to do the mod this weekend. Question is, do I have to disconnect the battery to see the results?
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    My car was much better when I disconnect the battery so I would say YES.
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Quote Originally Posted by Silentknight View Post
    No you dont, but as its only takes 20 secs, you might as well
    Swindon
    How do I disconnect the battery?
    Should I just disconnect one terminal, or both?
    Ignition keys in or out?
    keys out, and just remove the '-'ve terminal and tuck the lead where it can't flick back on and arc..
    Swindon
    Thanks alot, I'll do that ASAP and see if I notice much difference!
  1. Tech 2 help
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:35
  2. tech 32 ?
    By les287 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:04
  3. tech 2
    By jamesworts in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 08:17
  4. Tech 2
    By WHOOSH05 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 16:54
  5. Tech 2
    By cooky516 in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2008, 11:36
