Thread: radio code
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Default radio code
    how can i get the radio code for my vectra c
    it depends on what unit you've got..
    later CD30 and above units don't use an 'owner inputted' code..
    for earlier units, just look on your 'car pass' that came with the car, or contact VX who will give you the code for around £15..
    [Ex]Admin Duncan's Avatar
    If you haven't got a Car Pass with your car (bit of card with all the codes on it) then you can get one from the dealers - they charge about £15 I think. If they didn't supply one with the car (if it came from a dealer) then get them to get you one FOC.
    SNAP!! - although I wasn't aware of the newer ones having no code.
    the newer units are coded via TECH2, not by the user..
    thanks guys for input i brought my vec from a salvage site so i had no papers at all. the radio comes up with SAFE on it. the vec is a dti on a 04 plate if that is any help. ALL PARTS ARE IN SPRAY BOTH NOW. HOPEING to get all done for next sunday cheer for the help
    04 will be user coded...what you need to do is take down the logbook to VX and apply for a carpass from them..they'll send off for it, and that'll list the code for the radio the car was supplied with.. if it's a different headunit then they can give you the code from the radio's serial number.
  1. Radio Code
    By SarahP in forum Vectra C / Signum Troubleshooting
    Last Post: 11th July 2012, 00:18
  2. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  3. radio code
    By cerbrious in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2010, 22:36
  4. Radio code
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2009, 19:11
  5. radio code
    By farnorth in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2008, 18:33
