Thread: vec front brakes
    Apr 2006
    Southampton
    Default vec front brakes
    Hi All.
    I've got a problem with the front brakes on my Vec. Under braking at higher speeds (motorway speeds) I am getting a vibration up through the steering wheel. Had it before about a year ago and thought it was discs so replaced them. It appeared to get better but never really went away. At lower speeds under braking there is, what i can only describe as a 'pulsing' through the brakes - applying releasing, applying releasing etc...
    Any ideas appreciated.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    warped disks by the sound of it
    Apr 2006
    Southampton
    I put new discs and pads on about this time last year.
    Mar 2007
    Southport
    sounds like they've warped again if the pulsing has come back
    Do you sit with your foot on the brake pedal when you stop - if the disk is hot that amongst other things can cause warping
    Regular Member j13hdb's Avatar
    Nottingham
    There was a recall for ABS for earlier models-worth checking to see if it was done or if it's using the ABS all the time?
    Apr 2006
    Southampton
    Thanks. Any idea how I can check that out?
    Nottingham
    Basically ring the stealer up and ask if it's been done or check on the site first under RECALLS I think. I only know cause i took my Signum in last week and was told about the recall but mine didn't need it!
    Apr 2006
    Southampton
    Called 'em up and apparently it's all clear.
    yep, sounds like the discs again....
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Front brakes
    By mann3210 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 16:05
  3. front brakes
    By surreyl31 in forum Suspension, Wheels & Brakes
    Last Post: 26th February 2007, 06:52
  4. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
