Thread: Lighting problem
    Regular Member johnny kebab's Avatar
    May 2007
    Leighton Buzzard
    Default Lighting problem
    Hi all,
    Driving home last night I had a warning for a rear right brake light failure come on. When I got home, I had a look and all three are working. any idea what the problem is?
    Cheers,
    Johnny Kebab
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    There was a post about this the other day - IIRC it said the side light will take over the functions of the brake light if it fails so it may just look like they're all working - best to take the bulbs out & check them
    May 2007
    Leighton Buzzard
    cheers Ian!
    JK
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The rear s/light and b/light both use a 21w bulb (2 per side) and the can-bus sends a lower voltage to one to give s/lights and full voltage for the b/lights.The joys of can-bus/multiplex wiring!.
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    Quote Originally Posted by tyreman View Post
    It is annoying, i have done about 5 bulbs in 9 ish months (poss due to loud music) and i can never remember which bulb does the brake light. So i can see one is lower than the other but dont know which one is right.
    Melbourne, Australia
    This post may help to explain the behaviour of the Vectra C brake lights.
    I think I also read somewhere that if you have AFL headlamps and one fails, it will use the fog lamp as a substitute - can anyone confirm this?
  1. Lighting...
    By ijk571 in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 10:42
  2. Lighting help.
    By MJG91 in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2010, 11:50
  3. Lighting
    By John LE in forum Part Numbers
    Last Post: 15th March 2010, 02:33
  4. gid lighting help!
    By vauxdude in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2010, 13:57
  5. New lighting
    By fenderguitar in forum Quick Photo Album
    Last Post: 6th May 2009, 21:42
