Thread: astra SRi steering wheel on a Vec c ?
    Regular Member fellie's Avatar
    Lincoln
    Default astra SRi steering wheel on a Vec c ?
    well that answers that question..fitted to a pre facelift, 54 plate SRi
    06 astra SRi wheel and airbag, all 3 trims match my vec c SRi silver, horn works ( requires a bit of a fiddle, nowt hard ) , stereo buttons I didnt bother with.
    20mm less diameter, nicer shape, no knobbles on the rear of the wheel, much nicer
    Regular Member ALD's Avatar
    South Lanarkshire
    after giving up on getting the airbag (and deciding I needed the cash more) i've now found one, got a 55 plate airbag to fit my facelift steering wheel
    so looks like im going to fit this afterall, yours looks great btw
    did you fit the steering wheel yourself?
    Lincoln
    Yeah all self fitted .. pretty easy ..
    only issue you may have is the torx bit needed to remove the retaining bolt, are you fitting facelift to pre facelift ?
    any probs gimme a shout ... hth
    South Lanarkshire
    thanks m8, i have a torx screw set, i've seen the screw behind the airbag its quite big so hopefully i have the right size
    you mentioned about the wiring for the horn, what did you do there?
    and also the steering controls, did you just not bother or was there problems with these as well cause I cant lose my trip computer controls as i've fitted a dvd player in place of the original headunit
    mine is a pre-facelift as well (05)
    Lincoln
    removed the wiring from the steering wheel.
    remove the two brown wires from the loom.
    remove the brown wire inserts from the plug.
    push both inserts onto the left connections after fitting wheel, onto both left connectors. reconnect on wheel.
    rest of wiring was binned.
    your trip computer and cruise are on stalks, these are unaffected
    South Lanarkshire
    Quote Originally Posted by fellie View Post
    my controls for the trip computer are on the wheel, did you have the older style wheel before then? mine had wheels not buttons - full canbus
    edit: just checked your old wheel in for sale sections, i see its the older style with the buttons, i'm now a bit more confident that the wiring will fit without chopping any wires
    Lincoln
    you should be plug and play then bud ..
    I had half canbus 6 button wheel as per pic .
    Just pull your airbag out ( disconn battery first obviously ) and you should see exactly the same wires on both wheels
  1. Astra SRI steering wheel
    By Mark-R in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2013, 23:47
  2. Astra SRI steering wheel
    Last Post: 15th June 2012, 22:47
  3. Astra H Sri Steering Wheel
    By e55ex_rob in forum Styling
    Last Post: 17th April 2012, 06:58
  4. Astra Vxr steering wheel
    By vinty firth in forum Styling
    Last Post: 12th March 2012, 08:11
  5. Astra VXR Steering Wheel.
    By leeds vectra in forum Bodywork & Interior
    Last Post: 2nd July 2008, 05:16
