Results 1 to 10 of 17
Thread: Debadge procedure
    Jul 2006
    Mexico
    Default Debadge procedure
    Ok mates I might debadge the trunk this weekend, I will like to remove the logo in the middle of the trunk, boot as I think you call it, It has a nasty big chrome "Chevrolete" logo wich I dislike.
    After reading some threads about it what I get is that itīs glued to the paint, and to get rid of it you basically heat the thing with a hair dryer or such, and then you take it off right? and to get rid of the residue left you might use lighter fluid or some sort of scratch remover.
    Any other ideas for this simple matter?
    Regular Member silverhairedracer's Avatar
    ESSEX
    Use your credit card that way you will not damage the paint work,the residue "glue" you can remove with a tar remover[you can this at most auto shops],and polish well afterwards.
    http://forum.vectra-c.com/attachment...1&d=1176727169
    Regular Member shan's Avatar
    I never heated it up.
    I just used some fishing wire. Slide it over the badge and use it like a saw to cut the double sided sticky tape off. You will have some sticky tape left on the metal work.
    I then used tar and bug remover to soften it up a bit and it peeled right off.
    Looks much better with the bagde off.
    Regular Member Merick's Avatar
    Mar 2007
    Wigan & Preston
    I spent forever rubbing away at mine (the glue that is ) as i had nothing to hand to remove it.. an hour later, fingers almost bleeding, i remembered i had some WD40 lying around.. took it off in no time with that!
    Sweden
    Have used warm water to soften the doublesided stickytape and
    tar remover for cleaning up.
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    I used dental flos followed by bug and tar remover - no effort required!!
    Regular Member Rob_the_Scot's Avatar
    London
    Well I started to de-badge the back last night, just the letters on the chrome strip and the NHS healthcard worked a treat. Need to go get some Chrome polish today...might take the griffen off, not sure yet
    Jul 2006
    Mexico
    Thank´s all you mates. I think I´ll go with the hot water better than the hair dryer. And the WD40 sound´s like a great alternative.
    Regular Member joao's Avatar
    May 2007
    cannes, france
    look my car
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Pour a kettle of boiling hot water over it the wait a few seconds until it is possible to touch badge or trim you are removing.Then it should slowly peel off as the glue will have softened. Then use t-cut or tar remover to take away the excess sticky stuff.
  1. Vectra c fob re-syncing correct procedure please
    By barks in forum Electrical & ICE (including SatNav)
    Last Post: 12th February 2013, 01:47
  2. Auto lights/Dimming Mirror Tech2 Procedure
    By Aidi in forum Electrical & ICE (including SatNav)
    Last Post: 27th April 2011, 21:19
  3. Details product/procedure questions
    By dolf.peeters in forum Detailing and Car Care Discussion
    Last Post: 3rd June 2010, 22:51
  4. Boat launch procedure...
    By JohnnyB in forum Comedy & Humour
    Last Post: 7th August 2009, 17:02
  5. Gearlinkage adjustment procedure
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2009, 09:10
