Thread: brakes
    Mar 2007
    fleetwood
    Default brakes
    hi all just had my brakes done cos the symbol cam up on the dash my question is how do i now get rid of it ie what does it need ,do i need it putting on the diagnostic ...help will be most greatful..
    Regular Member stickshift's Avatar
    North London
    Did you get the sensor renewed aswell? If you didn't it will not clear!
    Mar 2007
    fleetwood
    not sure if i didn't how much is the sensor
    North London
    No more than than a tenner. Who did the work?
    Mar 2007
    fleetwood
    local garage
    also are they hard to fit
    really easy to fit the sensor wire.. just push the clip into the pads and connect the other end to the under wheel wiring..it takes longer to get the wheel off..
    Mar 2007
    fleetwood
    can this be done with the brakes in place
    yep, you just use the 'window' in the caliper to get the wire into the pads....the other end is in fresh air..
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
