Results 1 to 10 of 18
Thread: Help Parrot 3200 and CD70 no mute
    May 2007
    Default Help Parrot 3200 and CD70 no mute
    Hi I have just installed a parrot 3200 using a SOT 122 lead to connect it to the CD70.
    When on a call the radio kind of mutes, the main speakers have the incomming call but the cd still plays through a speaker in the centre of the dash.
    On the SOT 122 lead there are three inputs for the mute, white - blue and yellow.
    I have tried all three but stillthe same problem.
    Any ideas?
    Rick
    Regular Member scott_150cdtisri's Avatar
    Jan 2006
    Crewe
    iirc connect the yellow mute lead on the parrot to the pink lead on the sot122
    hope that helps
    May 2007
    I tried that but the speaker in the centre of the dash stays on and the cd still plays.
    I thought it would stop the cd and say external on the nav screen.
    Jan 2006
    Crewe
    oh thats how i did mine,sorry
    May 2007
    Thanks,
    From everything I have read it should work but the centre speakers stays on.
    Feb 2006
    Dorset
    connect a mute to the mute wire on the headunit . should be able to ident it from the pin layout sticker on the unit. whats happening is the relay in the mute lead is flicking over but not shutting the unit down , if it is external in come up on the display.
    Jan 2006
    Crewe
    if he is using the sot 122 thats what the pink wire is for isnt it? when i connected the yellow from the parrot it worked for me and external in came up on the display
    Feb 2006
    Dorset
    not used that lead so dont know , you need to take a mute from your kit to the headunit , that will sort it .
    May 2007
    I have tried the mute wire direct but still get the same problem.
    I am now trying the phone in connections without the sot122 lead.
    May 2007
    Direct Phone connections did not work.
    Back to the SOT122 lead.
    Best I can get is the speakers palying the incoming call and the centre speaker playing the radio very low.
    Been at this all day, hands cut to ribbons.
    Rick
  1. parrot 3200
    By stuart bigboy in forum General items for sale
    Last Post: 5th September 2010, 18:15
  2. parrot 3200
    By Dwabo in forum Electrical & ICE (including SatNav)
    Last Post: 8th March 2009, 21:18
  3. what iso for parrot 3200
    By rorycarz in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2007, 20:49
  4. Parrot 3200 LS for £105!!!!!
    By Jamie in forum General Chat
    Last Post: 30th March 2007, 20:13
