Thread: Instruments temporarily out of action
    N E Somerset
    Default Instruments temporarily out of action
    I set off for work yesterday and speedo, tacho, temp and fuel gauges not working for the whole journey of 13 miles (but digi odo and trip working ok).
    Thinking maybe a fuse.
    Get to work, turn off, turn ignition on again and they are then working and have done since.
    Phoned Vx dealer, who says never heard of this on Vec 'C' but common on Corsa, press on instrument glass to re-seat multi-pin connector and to try this on mine if it happens again. If doesn't work, to bring car in and they will put on computer and check for faults.
    Anyone else had this problem and if so what is the cause and remedy (if known) please?
    I hate intermittent faults that cannot be explained.
    Thanks for any advice.
    'Never heard of this on a Vec C' - it's a common fault matey.
    It'll be a canbus unit that's not registered correctly. Usually a 'reboot' fixes it for good.
    N E Somerset
    Cheers for the info AJA, how do you re-boot it?
    Is it a case of battery disconnect for a few minutes or a trip to the dealers.
    As a matter of interest, what causes it in the first place?
    By 'reboot' I mean restarting the ignition.
    I've no idea what causes it matey. We've had reports that different canbus units fail to start correctly on different occasions.
    If it's doing it persistantly it's a trip to the dealers I'm afraid.
    N E Somerset
    No it has only done it the once so far.
    What would they have to do if it was a persistant fault?
    I've got Network Q cover til Sept 2008 so hopefully covered if work required.
    I'm guessing they'd have to change the module if the fault is registered in the ECU and Tech2 can read it.
    N E Somerset
    Ok cheers, I'll get them to check when I'm next in there.
    As an aside, approx. how many members of this club have had this exact problem, would you say?
    Strange that my dealer hasn't heard of it, they're usually pretty good.
    [Ex]Admin Duncan's Avatar
    http://forum.vectra-c.com/showthread.php?t=22596
    Have a look at that thread - it's got some other info in that may help.
    N E Somerset
    Thanks Duncan, lots to go on there.
    Gonna have to go into the dealers and report it properly I think and get it checked out.
    Good to be well informed before going though.
    Regular Member Karl's Avatar
    Sunderland
    I know three people have had this problem with new "C"s at work.
  1. ECU Removal - not broken just temporarily?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 10th June 2012, 01:12
  2. Losing instruments
    By CBag7 in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2009, 16:02
  3. Instruments go dead
    By astrocat in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2009, 00:32
  4. What instruments....
    By lofty in forum The 'Off Topic' room
    Last Post: 5th November 2008, 04:09
  5. Instruments problems!!
    By andy1103 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th June 2008, 21:09
