Thread: K&N induction kit or K&N filter element ???
    Mar 2007
    Staffordshire
    Thumbs up K&N induction kit or K&N filter element ???
    Just wondering what would be the best one to fit to my 2003 vec C 2.2 sri ? Don't want something that sounds loud like a boy racers souped up nova but i want something that makes a difference? Any thoughts or advice would be helpful.
    Regular Member j13hdb's Avatar
    Nottingham
    Default Induction kit
    Just fitted the induction kit to my 3.2 and at low revs you can't hear a thing but when it goes above 3000 rpm it growls loudly and then quitens off.It's meant to give 5bhp more but it certainly picks up better!
    Motorway driving-no extra noise whatsoever-unless you floor it!!!
    Regular Member Lightboy's Avatar
    May 2007
    Reading, UK
    Hi j13hdb, quick one if I may.... how / where did you place the air feed to your induction cone? I've got a vectra gsi and can't find any space between the front grilles and the airbox to fit a reasonable sized pipe!
    Feb 2007
    North west
    a 3.2 will sound great with a kit. On a 4 cylinder id go for a panel filter and an air box mod.
    Nottingham
    Basically it's stuck behind the headlight- has to be approx 4" away from the airflow- ie the grill. i took one of the engine mounting bolts out and bolted the little stand into it with the bolt then cable tied the arm to it. The cone is just behind the light and if you pull it up it just touches the metal cross member (that has the bonnet catch in it). I've left the 2 small cold air feeds in place that sit over the airco rad. Don't push it out beyond the rads it runs fine behind and I think it's fair to say is made to go behind the light!
    WAIT FOR THE GROWL OVER 3000 RPM!!!
  1. K&N filter or induction?
    By chrissy white85 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2012, 13:41
  2. Air filter or Induction Kit???
    Last Post: 12th October 2012, 21:26
  3. Induction kit and Air filter
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 26th October 2009, 00:00
  4. K&N Filter and K&N Induction kit...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 21:38
  5. Which air filter/induction kit?
    Last Post: 9th July 2007, 17:12
