Thread: silly question really
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Default silly question really
    how much oil is needed for a oil change on a 1.9 cdti 2004
    i think its 4.3 lts but can anyone confirm
    thanks
    baz
    [Ex]Admin Duncan's Avatar
    Yep, 4.3l if you change the filter. 1l between max and min on dipstick.
    Mar 2007
    swindon
    cheers duncan
    No prob. Obviously don't whack in 4l straight away as there will still be a bit hanging around in the engine, I'd put in half a litre less then let it settle and top up as required.
    (Apologies if stating the obvious! )
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Stupid Q, I know the oil level should be 4.3 Litres, but how is that shown on the dipstick? Is it in the middle, minimum or maximum?
    delete duplicate post
    With the correct amount of oil in the engine, the dispstick should indicate max on it.
    From min to max is 0.7 litres on the the 1.9 CDTi engines. So if on the min level you would only have 3.6 litres of oil remaining in the engine.
    Note however, most dipsticks are 1 litre between min and max (excluding the 1.9 CDTi engine and possibly the Z22SE - found 2 different bits of info on the Z22SE)
    Regular Member 130786howe's Avatar
    Nov 2010
    wales
  1. Bit of a silly question but...
    By ijk571 in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2011, 11:26
  2. A silly question??
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2011, 12:11
  3. Might be silly question.....
    By scotty84 in forum Electrical & ICE (including SatNav)
    Last Post: 20th December 2010, 22:16
  4. Maybe a silly question but hey ........
    By Coastie in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2007, 09:21
  5. Maybe a silly question but hey ........
    Last Post: 13th April 2007, 19:02
vectra c I put in 4l of oil instead of 4.3 l is it ok
