Thread: unsure about noise
    May 2006
    North yorkshire
    Default unsure about noise
    i have a rumble type noise when driving. not sure where its coming from but it seem constant, does get louder as i go faster or when i go round a corner. its like tyre noise but does change when going over different surfaces.car drives in a straight line and brakes in a straight line.
    anybody any ideas?
    Regular Member Helibuddy's Avatar
    May 2007
    Standish, Wigan
    If its any consolation I'm having the same problem with my Signum. I intend to swop the the wheels from front to rear at the weekend and see if it makes any difference as I have different tyres on the rear. At the same time I'll check the wheel bearings. I will report back if I find anything.
    Regular Member daneboy35's Avatar
    darvel,ayrshire
    Does it sound as if its coming from one wheel,if its like a droning noise it could be a wheel bearing
    May 2007
    Standish, Wigan
    Thanks for that. Yes it does come from one wheel and its like a droning noise but the noise does change when going over different surfaces. That's why I thought tyres, but it has recently had new discs and pads, so maybe they knackered the bearing when doing this.
    East Midlands
    Had a similar problem and thought it was a wheel bearing, turned out to be the rear tyres were knackered. The tyres were uneven on the inside and that was due to knackered rear shock absorbers and the car's only done 35k.
    Chester
    I have had my Signum for 12months now done 35k and have always had this like rumble noise coming from the front, starts about 15mph and its a bit like a wind noise but think its coming from the o/s front area. I had a lot of road noise from the rear and 2 dealer techies didnt think that was abnormal but once I changed my rear tyres the noise went. Then a few months later I changed my rear shocks cos they were leaking slightly then started banging now and again , the rear seams nice and quiet now. just before the 3 year warranty run out i had a mot and my o/s front spring had snapped. swapped under warranty but the rumble has always remained. with new springs on the front and shocks on the rear i have decided to replace both front shocks and the o/s wheel bearing. I got a good deal to supply all 3 but now just gotto get them fitted, im hoping its gunna sort the rumble sound, i cant think of what else to try.
    May 2006
    North yorkshire
    thanks for the input going to check the front tyres(nct5) as one is worn more than the other and possible rear end too this weekend as well as a service. Its not a droning noise and maybe its just me but its seems to be worse when the weather warm. its not as noticable in a morning as it is in the evening when returning home.
    Regular Member wardy's Avatar
    Chichester
    I've had same rumble noise but only when I go over one particular road, which doesn't seem such a bad or uneven surface.
    As I don't drive on that section often I've ignored it. Don't get any sound at all like that on any other road, very odd.
    Regular Member daveloz1's Avatar
    cheshire
    just had same problem with loud droneing noise found that rear tyres had worn un even so had some part worns put on and now nice and quiet wierd problem but vauxhall said to me its a problem with some vectras that vauxhall havnt rectified and doubt they never will after so long
  1. Unsure what to do????
    By mspvxr in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2013, 17:08
  2. unsure of next mod ?
    By tiimi in forum Styling
    Last Post: 13th January 2013, 12:07
  3. slightly unsure with the vec
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2011, 21:35
  4. Xp2 wheels fitted but unsure!?
    By Jow20 in forum Styling
    Last Post: 22nd March 2011, 14:54
  5. Unsure what do you think
    By steve0 in forum Styling
    Last Post: 4th August 2009, 19:29
