Results 1 to 3 of 3
Thread: Gearbox problems???
    Mar 2007
    Blyth
    Default Gearbox problems???
    hi all, ive had my vectra in for being a ****** to get into any gear when the clutch pedle is first pressed, they said an adjustment was needed payd £40??? and it was a as smooth as a babys....well u know wot i mean 2 days later same problems again it "crunches" into gear, ive already had the cluch changed due to the "jumpin" into the back of a persons car, and with it being a sunny day yestereday was out drivin with the window down and u can hear it "crunch" into gear - any ideas???
    [Ex]Admin Duncan's Avatar
    The F40 gearbox (what you have - especially the Wide Ratio version fitted to the 1.9/3.0 CDTi) seem to be prone to this. Some members (Ian C for one) had the gearbox on his 3.0 replaced eventually as it got worse. The F40 (Close Ratio) in the 2.0T can be a bit notchy, and some members I think have had problems, but not as much as the Wide Ratio one if I recall.
    Have a search around for gearbox crunching and it should bring up a few threads.
    http://forum.vectra-c.com/showthread.php?t=4126
    That's Ian's case for starters - but type in 'gearbox crunching' into the search window and you'll get ten threads pop up - some more relative than others.
  1. gearbox problems 6 speed
    By Даниил in forum Engine & Drivetrain
    Last Post: 8th October 2011, 20:43
  2. please help!!! vectra 2.0 dti ls, gearbox problems
    By tazzy in forum Engine & Drivetrain
    Last Post: 11th January 2009, 00:17
  3. HELP! Automatic gearbox problems
    By dracunciliasis in forum Engine & Drivetrain
    Last Post: 14th May 2007, 21:48
  4. 3.2 GSi Gearbox problems
    By Scooby in forum Engine & Drivetrain
    Last Post: 7th September 2005, 14:30
