Thread: signum knocking
    Regular Member keith's Avatar
    May 2007
    ROTHERHAM
    Default signum knocking
    i am on my third signum and everyone has had the same clunk from the rear but, the dealers cannot find a fault. has anyone had the same problem? if so what it? i am pulling my hair out.
    SOMERSET
    The only way i solved a problem with a knocking in my vec was to take everything out(everything)and i put my 12 year old in the boot and went slowly around the block and found that the tailgate needed adjusting on the locking bit. Lowered the mechanism and perfectly fine.
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Mine suffers from the body panels cracking in the rear of the roof or the rear quarter panel -Vauxhall can't fix it so they are trying to find a replacement which is easier said than done....
    Regular Member j13hdb's Avatar
    Nottingham
    If it's not the shockers have a look at the boot. Open it and on each side is a bolt covered in rubber actually on the boot. these can be turned left or right to even the closure of the boot. When the boot is shut push on each side above the area of the bolt and see if there's any play in and out then move the bolts accordingly until the boot is solid ith no play. This may take a few attempts but it's amazing how much rattling and clanking this may cure!!
  1. Signum 2.0 DTi knocking at 2000rpm
    By olid2002 in forum Diesel Engine related
    Last Post: 15th November 2012, 18:10
  2. Signum exaust knocking...
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 20:33
  3. Knocking
    By ianuk in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 23:47
  4. Knocking from car?
    By ectraz in forum Suspension, Wheels & Brakes
    Last Post: 27th July 2009, 14:52
  5. still knocking
    By adfrodsham in forum Suspension, Wheels & Brakes
    Last Post: 31st January 2009, 10:34
