Thread: Warning Light
    South London
    Default Warning Light
    Hi
    was just oput for a drive and the indicator light in the tacho display came on.
    The symbol is like a ships wheel with an exclamation mark through it. This,according to the handbook, indicates a blown bulb. I have checked all of the bulbs and none are faulty. Also, I did not think this function was available on my car, an 04 2.2DTi LS.
    The car seems to handle no differently to before the light coming on.
    Has anybody any thoughts on the above. I would welcome any advice.
    Regular Member videodoctor's Avatar
    Blackpool
    Be warned that when a bulb goes in the vectra then the the other filament in the bulb(ie tail and brake light bulb) will mimmick the other.So if the tail light bulb goes then the brake light will light up to mimmick a tail light.In other words as you go round the car it looks like all the bulbs are working.Its best to take out the rear tail/brakelight bulbs and physically check the elements.
    Quote Originally Posted by FRANKA View Post
    That sounds more like the Power Steering fault
    This is a circle with two bars connecting to the exclamation mark
    I've had this once, switched the engine off and restarted
    I suspect this was caused by stalling the engine and using the cars momentum to restart the engine!
    I've had the bulb failure fault light before and it looks like a bulb with a an exclamation in it
    Since my SRi is fitted with a Driver Info Display I also got a warning for the Front Fog Light, so diagnosis was quite easy
    Does this warning still show, or was it a one-off?
    If it is defintely a bulb, then check as follows, and walk round the car to make sure they are all as expected :
    hazard warning on, off
    Sidelights
    Main headlights, with full beam and fog lights -> that gives you all the remaining lights on
    Switch all to off, then check brake lights
    Finally, check reverse
    South London
    Thanks for your reply VideoDoctor
    As you said all of the bulbs looked okay but when I took them out to look at them one was blown.
    I have replaced the blown bulb and now everything is fine.
    Thanks again.
    Blackpool
    Glad to hear you got it sorted.Thats what we're here for
    Regular Member Vec-6289's Avatar
    May 2007
    Cirencester (Days off) Lyneham (Work days)
    I had the same happen to me last week.
    The rear light was acting as the brake light. The warning was intermitent though, sometimes it would stay on for 5 mins then it would go off. When i took the bulb out, it had blown, but the filiment could move in the bulb, so ever so often it would re-make the connection and function correctly.
    Still changed the bulb (cost me all of 84p) and it is now functioning correctly again.
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
