Thread: tech 2?
    May 2007
    south ockendon
    Default tech 2?
    had a nose about on ebay and they seem to have tech 2 units for around 80 quid
    are these the 'real' ones and do they do the job?
    what does a tech 2 unit look like and what software would i need for an '06 plate 1.8 design
    Regular Member Stu14t's Avatar
    Perth, Scotland
    I think this is the correct one pictured below.
    You need the one that can interface with CANbus.
    You may also need TIS2000 software, not sure though
    Stu
    [Ex]Admin Duncan's Avatar
    At £80 it most definitely won't be the Tech 2 unit you've seen at dealers (like in the pic above) as they are £2k+!!!
    It'll probably be, at most, a fault code reader and maybe other simple diagnostics, but it won't be able to change/reset anything on the car.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    there is a programe availiable called ''auto enginuity'' by a company called ''gen dan'' that reads all full and half can-bus systems on vx's from 2000 onwards, my dad ( 'tech 2' on here)has it and i think it cost him somewhere in the region of £100.00, they are free to update and do all sorts of other things apart from fault code reading......
    hope this is of some use to you all as i said i was going to find out about this for someone else a few weeks ago
    Midlands Mod Shop - NFFC.
  1. Tech 2 help
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:35
  2. tech 32 ?
    By les287 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:04
  3. tech 2
    By jamesworts in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 08:17
  4. Tech 2
    By WHOOSH05 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 16:54
  5. Tech 2
    By cooky516 in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2008, 11:36
