Thread: Buffing machine
    Regular Member rickyroo's Avatar
    shropshire
    Smile Buffing machine
    Does anybody know how to use this toy effectively, I applied the megatrends glass finish wax (rip off) with it and left to dry as stated for 3minutes. Obviously it was white chalky residue on car then changed pad to buff it off, it buffed of the wax but you could see the wax still on the paint as if it was under the paint a dullish look.
    Washed off and started again but tried doing the same but very thinly by hand using a fine cloth.
    Results the same, im at a loss.
    My mate says that I should always use the buffer with the pads wet otherwise it will reck me paint, but if I wet the wax surely will look rubbish.
    Please help my limited polishing knowledge.
    Regular Member fellie's Avatar
    Lincoln
    Get some specialist instruction before you end with a scary re-spray quote
    Failing that, get some decent applicators, a few bottles of Meguiars, a decent microfibre or 5 and leave the machines to the experts ..
    I always apply products so thinly you can just see a haze, unless its a paint correction, then apply as much as required
    shropshire
    So stick away from the machine then?
    Lincoln
    chances are you will do more damage than good with it ..
    anything you cant remove with scratch-x / t-cut or the like, can only be removed with either new paint or a professional and his random orbiting cleverness..
    have you tried clay ? ( serious question )
    shropshire
    No mate I haven't does it work on light colours like lighting silver?
    Lincoln
    clay works on all paint types ... the dirt it took off mine ( star silver I think ) when I first used it was a sorrowful sight lol ..obviously the previous owner never washed the paint, never mind anything like wax or polish
    when you have washed it, rub your hand over the paint ( surfaces that face upwards are the ones to do ) if you feel dots, rough patches etc, you need to clay, then paint clean, polish wax seal etc ..if it already feels silky smooth, as well cared for paint should, then clay is not needed ..
  1. Want to use a diagnostic machine ? Or program a new key to your car ? Use my machine !
    By cyberbobdude in forum Vectra C / Signum Troubleshooting
    Last Post: 7th July 2012, 21:42
  2. buffing lens covers
    By chewy71 in forum Detailing and Car Care Discussion
    Last Post: 12th October 2010, 15:39
  3. what a machine.
    By Hideous in forum The 'Off Topic' room
    Last Post: 11th July 2009, 16:44
  4. Machine polisher
    By aerodynamic18 in forum Northern Ireland (RO - Vacant)
    Last Post: 12th May 2009, 22:57
