Results 1 to 10 of 30
Thread: Tyre question...
    Jul 2006
    liverpool
    Default Tyre question...
    Hi Guys
    ok.. same old question i know.. but which tyres would you recommend for my 3.0cdti??? Its on 215/50 r17's (Extra load) at the mo..
    Is it important to have extra load tyres??? What difference does it make compared to standard tyres???
    Anything must be better than the Goodyear NCT5's that are on at the mo... the seem dreadful in the wet.
    Any advice.. gratefully received...
    Darren
    [Ex]Admin Duncan's Avatar
    For the 3.0V6 it's very important to make sure you have the extra load tyres. It needs it due to the extra weight of the engine (heaviest of the whole range).
    As for what tyre - how long is a piece of string. Depends what your priorities are - good wear, good grip, good balance etc.
    Jul 2006
    liverpool
    Thanks for that piece of advice Duncan.. I thought thats what it could mean..
    As for the tyres.. Im looking for something thats got good wear but also good grip in the wet and dry.. I know its a hard balance to find.... but i was just wondering if there was anything else out there apart from Michelin Pilots??
    I think the fact that ive got a slighty odd tyre size is not helping!
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Do what I have done and change from 215/50x17's to 225/45x17's.
    They fit the wheels, Vauxhall list them to fit. They are cheaper and there is greater choice.
    You will find stacks of threads on here about this.
    Jul 2006
    liverpool
    hey thats a good idea..!
    but does changing the sizes mess up the speedo???
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    If you are really bothered - yes it does - if not then no.
    If yes you will have to o the vx dealer and have the tyre size changed in the ECU using Tech2. I had this done - 10 mins tops - £££ for the pleasure.....
    Jul 2006
    liverpool
    oh right.... Hmm...maybe i wont then! lol!!
    Ive just been reading the debate about tyres in the threads.. I may have to stick to the original ones now anyway... ive got a 3.0cdti.. it needs the extra load tyres....
    Bummer
    Cheers for your help though guys!!
    Feb 2007
    The pool
    Quote Originally Posted by riverdees View Post
    Bummer
    225/45/17 do come in XL as well - still more choice and in the main, cheaper.
    Try this site for prices
    You can use any :
    215/50R17 XL 95W
    225/45R17 XL 94Y
    The cheapest tyres to keep to the original NCT5 215/50R17 XL 95W were £130 each, after much haggling
    I looked at other 215/50R17 XL 95W, but they too were about the same price
    I then looked at 225/45R17 XL 94Y and not only was there a greater choice, but they are about 25% cheaper
    I then compared the treadwear / traction /temperature ratios
    The equivalent Good Year comes out as the F1 GSD3
    I haggled for £90 each
    As a result I am now in the process of changing over
    I also have access to one of only three Accident Investigation computers
    On my last visit to the one in Aberdeen I did a comparison for a Vectra C 3.0 V6 CDTI on various tyres
    You can get away with the standard tyre, but the weight of the 3.0 V6 CDTI is just a few kilograms over the limit
    What can happen is that if you are cornering, at full speed, and you then suffer a tyre failure, you should be able to bring the car safely to a stop
    In some of the analysis carried out it was clear this would not happen and the car would suffer severe understeer and if braking was required this could also result in oversteer
    The worst example and result was for a rear tyre failure on cornering
    Clearly these aren't things you want happening
    However, be assured the calculations were for full speed and not more than 80mph
    Question
    Ask Mark the Cabby what happened to two (if not three) of the tyres that were fitted wrongly by a tyre place. They didn't fit the correct load rating (just used the standard one) and he had catastrophic failure of the tyres (each at different times) - they were shredded. It took a bit of time to get to the bottom of the problem - hence the subsequent number of failures in that time. Failures were at normal motorway speeds/normal driving - not whilst cornering etc.
    After seeing what happened to standard load tyres on a 3.0CDTI, I'd never, ever put anything other than Extra Load on if I had that engine.
  1. tyre question
    By CLOMP in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 19:56
  2. yet another tyre question
    By gordy07 in forum Suspension, Wheels & Brakes
    Last Post: 31st May 2010, 08:34
  3. Another tyre question
    By dave300776 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2009, 08:46
  4. Another Tyre Question
    By redraptor_141 in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2009, 22:29
  5. tyre question
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2008, 22:33
