Thread: How to remove the dashboard
    May 2007
    Somerset
    Default How to remove the dashboard
    Does anyone know how to remove the dash on a veccy C? I want to check that there is a bulb fitted for the trailer warning light.
    I tried to access it by going in through the right hand air vent but this didn't work.
    Since the haynes manual isn't out till later this year I'm hoping someone would have done this already.
    How brave are you? It's quite a number. I can get the procedure for you if you fancy a go.
    As for checking for a bulb, it's not going to be a normal bulb as such, it'll be a LED type thing (SMD) attached to a circuit board. If it doesn't have that you can't really add it. I'd have thought the light/feature would be there on all models, it will just be activated when the towbar electrics are fitted and a Tech 2 is done. Maybe worth checking that first before you start to dismantle your dash?
    May 2007
    Somerset
    Hi Duncan
    If you can get the procedure then I'd love to have a look. I'm pretty good with electrical stuff, so surface mount isn't a problem.
    I will check with the garage though about the Tech2. All the trailer lights work when plugged into the car (using the standard vx module), so I was hoping that the car didn't need Tech2'ing. I think it's about £40 for a vx mechanic to plug in his box and press 5 buttons!
    I'll dig it out for you, although I'd say almost 100% that the SMD will be there.
    I'm positive the car needs Tech 2ing when a towbar is fitted to activate that feature. Maybe PM Matt or GSi3.2 on here as they've had a good bit of experience with towbars.
    Oct 2006
    Wellingborough
    Sure it will be a Tech2 job, everything is. Sometimes i'm suprised i can open the petrol flap without a Tech2.
    Regular Member Coastie's Avatar
    Feb 2007
    Suffolk
    one thing is for sure, having previously removed the dash from a previous vehicle (my Cavalier) I would never try to do it again.... blinking thing
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    Angle grinder!
    Feb 2007
    Suffolk
    Quote Originally Posted by plasma View Post
    Angle grinder!
    Angle Grinder and an Axe !
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    stepping in for Mark GSi, as thats his favourite toy lol
  1. using carbon film and need to know how to remove a bit of the dashboard
    By Blurry120 in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2012, 22:49
  2. Dashboard Shine/Reflection : How to remove?
    By Envy in forum Detailing and Car Care Discussion
    Last Post: 13th June 2011, 21:17
  3. dashboard bit
    By porthy-t in forum Styling
    Last Post: 19th January 2010, 19:18
  4. Replies: 12
    Last Post: 30th November 2008, 18:46
  5. Dashboard Damage
    By Cerealuk in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2007, 23:12
