Results 1 to 10 of 14
Thread: Speaker number difference?
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Default Speaker number difference?
    Sorry if this has been asked before, and also if its in a spec sheet anywhere...but i couldnt find it...anyway...
    Looking in a 2003 MY Brochure at the stereo spec at the back, says about the CDR2005 and CCR2006 etc but its the speakers that i dont understand...
    It says the CDR2005 has 7 speakers and the CCR2006 has 9....but firstly why the odd number?, as surely there is an equal number of 2 (1 full range& 1 tweeter) in each door?, thus evening the total number out to 8 (i originally thought there must be a small subwoofer somewhere making the odd number, but apparently not)
    And secondly, why the difference anyway, which 2 speakers are missing from the 2005 set-up, mid range or what?
    any info greatly recieved
    Regular Member simac's Avatar
    Wirral
    There is one speaker on the dash in the centre of the grill towards the windscreen. So a seven speaker would be 2 full range to rear doors, 2 full range and 2 tweeters to the front doors plus the dashboard speaker.
    I should imagine that the 9 speaker system has tweeters in each rear door.
    HTH
    [Ex]Admin Duncan's Avatar
    The difference between 7 and 9 is the rear door tweeters. On 9 setups they are near the handle - you'll see a grille (although a grille doesn't always indicate speakers as some 7 models have them - just no tweeter behind)
    The odd number is the centre speaker on the dash. The vent that runs along the top of the dash by the windscreen has a centre speaker under the centre section. More for speech like on Radio 4 etc.
    EDIT: Beaten to it!
    Wirral
    LOL someone had a query which I actually knew the answer to makes a bl@@dy change LOL
    The rear doors on my 03 SRI have the tweeter grills but no tweeters behind them.
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Aha cheers...i didnt know about the centre speaker...superb thanks guys
    I wonder why they decided not to put the tweeters in the back on a 7 speaker set-up?...skinflints! lol...easy enough to add though i would think?
    Quote Originally Posted by MadOnVaux! View Post
    As long as the wiring is there and the head unit supports it.
    Regular Member Merick's Avatar
    Mar 2007
    Wigan & Preston
    what kinda speaker is under there and how easy is it to replace.. also.. is the speaker still functional if you replace the HU with an aftermarker unit?
    Small tweeter - easy to remove. Don't know to the last question.
    Feb 2006
    Guttedsville
    Certainly is. The Dash speaker also gives a bit more detail to most types of music. Also putting the tweeters in the back is a doddle, even if, like mine, the wiring isn't there.
    All I did, was remove the door cards, take out the speaker, open the plug, feed the wires in and close it, connect the tweeter, snap it in place and rebuild the car. Job Done.
    Took me about three months (literally) to get the handles off though!
    Mar 2007
    Wigan & Preston
    Oooh.. might have a go at digging it out and see if it's on at the moment
    Cheers Duncan.
  1. Part number for dash speaker?
    By mr.ian in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2010, 20:14
  2. Replies: 33
    Last Post: 16th December 2007, 23:28
opec vectra c speakers number
