Thread: fuel filter
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Default fuel filter
    any tips on changing the fuel filter on a 1.9 cdti 2004 vectra (i have never done this before on any car so an idiots guide would be helpful)
    any part numbers will also be greatful
    cheers
    baz
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Have you looked on how2 my be something in there
    Regular Member Eddie Dee's Avatar
    Feb 2007
    BELFAST
    Thumbs up
    Did mine a few weeks back.
    Unplug multiplug and disconnect pipe flowing in from the right.
    I used a hammer and screwdriver to loosen the ring but be careful as these can be damaged easily.Must be a special tool for this!
    Filter will then lift out with the housing,twist paper filter from housing.
    New filter comes in protective plastic cover, you will need to use the cover to fit the filter to the housing as the new filter is not to be touched by hand for some reason?Twist new filter on to filter head housing and carfully fit your new seals to filter housing.Offer it back into the reservior and tighten up ring by hand and then a few taps with hammer and screwdriver again be very carefull do not over do it. reconnect pipe and multiplug and start engine to self bleed (it may stall untill system is bled up.)
    I ordered genuine parts from my local autopart shop and the guy told me he had the same filters in non genuine stock but same brands at about twenty quid cheaper so check it out.
    Hope this was helpful
    Mar 2007
    swindon
    Thumbs up
    Quote Originally Posted by Eddie Dee View Post
    cheers m8
    in all about a 20 min job if that?
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. Fuel filter help
    By wolvesdaz in forum Engine & Drivetrain
    Last Post: 4th March 2011, 10:47
  3. fuel filter
    By lordreeson in forum Engine & Drivetrain
    Last Post: 28th February 2011, 21:15
  4. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
