Results 1 to 10 of 18
Thread: Oil light after 2500 miles???
    Scunny
    Default Oil light after 2500 miles???
    I have a 07 reg Vectra 1.9cdti (150). The oil light has just come after only 2600 miles. I'm new to Vectras and Diesels, do they use a lot of oil? Is it normal to need oil already??
    I haven't checked the dipstick yet as I have only just parked up so I guess it needs to settle.
    Regular Member Karl's Avatar
    Sunderland
    iirc the oil light comes on when you have used circa 2 litres (ish), in which case Vauxhall suggest 1ltr per 1000 miles is acceptable. It does seem to calm down a touch though after a while.
    Scunny
    Also what kind of oil do i need? I don't have the manual with me.
    Thanks again
    Sunderland
    most seem to recommend Vauxhalls own
    Scunny
    Checked the dipstick last night, and it was on the minimum. I'm very suprised it's so low already. Is it possible that it didn't have the correct amount of oil when delivered?
    Feb 2006
    Guttedsville
    I expect it's used a bit during it's bedding in process.
    And before anyone starts, I don't care what you say about modern engines and tolerances and all that, they still need go through the process!
    Replenish the level, then keep an eye on it weekly, like you should be anyway, I would expect the useage to stop or at least settle by 10000 miles or so, any more and it's using too much.
    Scunny
    Will do, thanks
    May 2006
    scotland
    Rusty, I bought my Vectra (150 CDTi SRI) at 10000 miles and have went 8k miles before doing an oil change, the oil level had not moved in 8k miles though. I did not have the car for the first 10k miles so cannot comment on its consumption up to that point. Mostly motorway miles I do. Good luck
    Scunny
    Went into local Vauxhall dealer to get some oil. They said it was not usual for the engine to get through a lot of oil, but not unheard of, and usually settles down after a while.
    Chester
    Quote Originally Posted by rustywheelnut View Post
    Mine was exactly the same when I bought it new in 2006. I've put more oil in this one than my last 5 cars put together. It has settled down now at 20,000 miles
  1. Replies: 13
    Last Post: 31st August 2012, 12:05
  2. 2500 miles, lapped the ring, gets back to England
    By Kev_G in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2011, 12:58
  3. spanner light on for about 2 miles
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2011, 18:45
  4. Spanner Light Comes on For 1.5 Miles
    By peakfreak in forum Troubleshooting
    Last Post: 14th September 2010, 23:40
  5. Service Light after 100 odd miles
    By Technicalway in forum Troubleshooting
    Last Post: 20th February 2008, 23:57
