Thread: Query! Clinking noise from front
    Mar 2007
    Australia
    Default Query! Clinking noise from front
    Hi all,
    I'm getting this clinking noise in the front suspension when I going over bumps... However, not all the time....
    Checked the shock absorber, but it seems to be fine.
    Can it be the anti-rollbar?
    Regular Member Harry's Avatar
    Uxbridge, London
    i've got the same problem, but only on cold mornings.
    could either be the anti-roll bar bushes as you mentioned or you may find that you need to the 'spring seat mod', do a search on the forum and you'll find part numbers. essentially it's just a piece of plastic that slips over the top coil of the spring in order to prevent it slipping when going over bumps.
    radiator mounts are also a likely culprit.
    Admin plasma's Avatar
    On the Forum
    272 Post(s)
    Engine : 150
    Mileage : 74000
    ^^^ Wot he said!! except the sleeve cover sits on the bottom of the coil in the pan.
    SOMERSET
    Me and Big Phil have had the same problem and the spring mod thing has been done and it was the anti roll bar bushes that stopped the creaking when its cold or going over speed bumps.
    Mar 2007
    Australia
    Cheers guys
    Will look into the spring mods and the bushes
    Feb 2007
    Sydney australia
    I am also getting the same noise when going over speed bumps, I also notice a similar noise sometimes when I drive along, almost like something expanding or creaking, could this be a result of the same issue already mentioned in this thread.
    yep, it could be....
    if you haven't had the spring mod done yet by holden, then get it done....and the antiroll bar bushes are prime candidates in your case..
    Feb 2007
    Sydney australia
    Thanks GSI, does this problem fall into the annoying noise category, or is my suspension is danger of giving way under me when I hit the wrong pothole (australian roads are pretty crappy).
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by MrBond View Post
    You've not driven over hear then mate. LOL
    it's more 'annoying' than dangerous..but poor roads do show up the wear in the links very easily..
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. Noise from front end?
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 09:41
  3. Clinking noise around 2000 revs after taking foot off accelerator
    By ChrisM in forum Vectra C / Signum Troubleshooting
    Last Post: 8th November 2009, 19:36
  4. Noise Query
    By 2.0 DTI SXI in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2007, 13:23
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
