Thanks Thanks:  3
Likes Likes:  3
Thread: Dash/clocks problem
    Oct 2010
    N. Ireland
    Default Dash/clocks problem
    The dash board on my Vectra is doing some weird things today.
    The speedo is stuck on 40mph and rev counter on 1500
    The only light which comes on is EML which goes off as usual upon starting the car.
    No before this a few weeks ago one morning the dash was dead, no lights or clocks working, then after driving for a bit all came to life again.
    Any ideas?
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    The dash itself of CIM?
  3. Thanks melvin thanked for this post
  4. #3
    Oct 2010
    N. Ireland
    Quote Originally Posted by horaa View Post
    I've tried removing and reinserting the fuses as recommended in another thread.
    Also disconnected the battery a while to see if it would reset.
    Never touched the ABS plug though, not sure how it comes up.
    Also tried tapping around dash/steering column.
    Been for a drive today too.
    Now luck with any of these.
    Is there anything else i can try?
    I have a long drive tomorrow, is there any risk the car could breakdown because of this?
  5. #4
    Regular Member Jon1796's Avatar
    Sep 2015
    Norwich
    28 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Possible the solder has cracked on plug to board.
  6. Thanks melvin thanked for this post
    Likes horaa liked this post
  7. #5
    Oct 2010
    N. Ireland
    Quote Originally Posted by Jon1796 View Post
    Thanks, Can the dash panel be just changed for another one or does it need programmed ?
    Think its easy enough to remove dash panel and have a look at the solder, might be hard to see the fault though.
  8. #6
    Sep 2015
    Norwich
    28 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Few options you can if your lucky buy one from people who will transfer data to your replacement, or read the info yourself and transfer the data(not hard with a few cheap/ish parts), which then no programming needed. Or replacement with code program in but mileage will then need to corrected. Best to get a cheap diagnostics o/c, v/c to read fault codes it’s not hard todo and can save a lot off time looking at the wrong thing. Also will let you program it in.
  9. Thanks melvin thanked for this post
    Likes melvin liked this post
  10. #7
    Oct 2010
    N. Ireland
    Just a quick update, today i was driving down the road and for no particular reason decided to push the trip counter reset button on dash and everything came back to life again!
    Hopefully it stays like that
    Cheers everyone
  11. Likes horaa liked this post
  1. Dash clocks info
    By jetsmike73 in forum Electrical & Ice (including satnav)
    Last Post: 26th July 2015, 10:53
  2. dash clocks in siggy
    By mark v6 in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2015, 21:35
  3. dash clocks
    By wobblywayne in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2012, 00:49
  4. dash clocks
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2010, 10:49
