Results 1 to 7 of 7
Thread: CIM ? Advice needed
    Regular Member JagRigger's Avatar
    Norfolk
    15 Post(s)
    Trim : Design
    Engine : 1.8 VVT ( No2 ! )
    Mileage : 308 k !
    Default CIM ? Advice needed
    My 1.8 VVT has developed a problem When you turn the key, either to the on or start, the power steering does not work first turn. Turn it off / on and it's fine. It has also once refused to start, and yesterday got an ABS light and rev counter 'needle sweep'
    I believe it to be the CIM - any other ideas ? ( NOT ECU / UEC / battery ) - swapped out already
    I did try to swap the CIM last week, but couldn't get the new one to accept the old keys - despite following on line guides. It gave a program error when trying to pair old key, although I understood I could do this ?
    Other than try again with a brand new key, and ideas ?
    Regular Member Jon1796's Avatar
    Sep 2015
    Norwich
    28 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Got a couple of cim’s here not sure there’ll be any good as the sensor ??? But also got t2win with oem mdi if you want to try again in programming.
    Sep 2015
    Norwich
    28 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Norfolk
    15 Post(s)
    Trim : Design
    Mileage : 308 k !
    Cheers Jon - I have the spare CIM and may try agin this weekend with a blank key. What concerns me is the fact I couldn't match old keys to new CIM when I thought this was possible with the un-named program. I've coded new keys ok in the past, but never mucked with the CIM
    Norfolk
    15 Post(s)
    Trim : Design
    Mileage : 308 k !
    Sep 2015
    Norwich
    28 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    From someone else I helped ages ago with cim he got it in programmed then removed and added his old keys, but if you want to try mdi and the different versions on my lappy give us a shout, you got my no.
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    I programmed the 2nd key with opcom as long you have the car pass but that's easy to obtain from CID
  1. Vectra CDTI 150 Front Shocks needed .. Advice needed
    By aps in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2015, 21:35
  2. Vectra CDTI 150 Front Shocks needed .. Advice needed
    By aps in forum Handling & Braking
    Last Post: 20th September 2015, 19:34
  3. Advice needed
    By spandy234 in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2014, 19:57
  4. advice needed
    By iasha in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 10:42
