Likes Likes:  2
Results 1 to 2 of 2
Thread: Engine do the hokey cokey
    Regular Member JagRigger's Avatar
    Norfolk
    15 Post(s)
    Engine : 1.8 VVT ( No2 ! )
    Mileage : ... 299 k
    Default Engine do the hokey cokey
    What a busy 4 days ! Set out to change the clutch on Saturday. My preference is to pull the engine and box, so had it back in later Sunday. Couldnít bleed it by any method and no fluid from the clutch master.
    So, new master cylinder Monday and hooray - now get fluid. As it turns out too much fluid - itís ****ing out the bell housing. The new CSC has let go ( no I didnít bleed at too high a pressure either - Blue Print part )
    Tuesday- engine out again, another ( Sachs ) CSC fitted and finally got it all sorted by 1600 Wednesday.
    Too old for this malarkey in this heat !
  2. Likes Jon1796, horaa liked this post
  3. #2
    Norfolk
    15 Post(s)
    Mileage : ... 299 k
    ...... and then she went to Devon for a week. Fully loaded down. Faultless and another 1000 miles done
  1. Reducer for the engine ventilation for all Z19DTH/Z19DTJ engine
    By Thunder in forum Engine & Drivetrain
    Last Post: 7th February 2014, 19:35
  2. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  3. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  4. Replies: 35
    Last Post: 5th May 2012, 15:32
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
