Thanks Thanks:  1
Likes Likes:  4
Thread: TC and ABS light, non starting, no fuses blown
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default TC and ABS light, non starting, no fuses blown
    Been a long time since I posted but I've had to buy an Insignia after my Vectra of 17 years that I bought new decided it wasn't playing anymore.
    Post a clutch and DMF change, the TC and ABS lights are on and it just won't try to crank. Starter is fine and it turns over if you bridge the exciter to the battery.
    I've looked through the fuses and swapped relays around but had no joy yet. I took the whole fuse box apart next to the battery to check for faults but found nothing obvious in wiring or the circuit board.
    Any other suggestions would be welcome.
  2. Thanks NeilGo thanked for this post
  3. #2
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    time to check for DTC's so scan it first... TC and ABS have nothing to do with the car not starting.
  4. Likes NeilGo liked this post
  5. #3
    Regular Member JagRigger's Avatar
    Norfolk
    15 Post(s)
    Engine : 1.8 VVT ( No2 ! )
    Mileage : ... 299 k
    May be a long shot, but check you have power to the ECU. When the wife's Astra lost power it was giving ABS / TC faults before it went totally
  6. Likes NeilGo liked this post
  7. #4
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    So it's all fix and it was entirely down to the Power steering unfortunately. The ECU CANBUS loops through the power steering for some reason and the plug with not in, so nothing could talk to the ECU :/ Sad face. Fortunately a friend came round with his laptop and the circuit diagrams and he quickly identified the common link as everything was showing present and fine except the ECU and power steering.
    Thanks for the replies.
  8. Likes Dog_Book, horaa liked this post
  1. Dash light for blown bulb, but no blown bulb
    By Khare in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd July 2022, 21:15
  2. car/spanner light.. would blown heater resistor make light come on?
    By Jampo1979 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd March 2016, 20:34
  3. Blown light warning
    By JB007 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2011, 14:18
  4. Blown Rear fog light bulb
    By Ben Chiles in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2011, 02:08
  5. Blown bulb warning light
    By Ant S in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2009, 23:09
