Thanks Thanks:  1
Likes Likes:  1
Results 1 to 7 of 7
Thread: Climate control too warm air mix
    Regular Member opel_estate's Avatar
    May 2008
    Sweden
    Vehicle : Opel Vectra C Estate
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 95000
    Default Climate control too warm air mix
    Hi ,
    I have a problem with the air in the car being too hot . The air coming out is really warm especially on days where the outside temp is lower than the temp set in the ecc. If i turn the ECC to like 18 degrees, the aircondition starts and i get cool air. i normally run the ECC at 22 degrees perfectly, set and forget like, now i need to fiddle with turning the heater up and down to feel comfy. Is there a temp sensor or something that needs cleaning ?
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    it's a sign of it needing a gas refill, on most cars it should be done every 2 to 3 years to keep working right.
  3. Likes NeilGo liked this post
  4. #3
    May 2008
    Sweden
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 95000
    I'd like to rule that out. had te compressor replaced and system refilled 3 days ago. I thought that would cure this problem. Forgot to mention the most warm air comes out of the leftmost vent in the fascia, so this could well be an issue with the air distribution flaps ...
  5. #4
    Apr 2016
    Ipswich
    93 Post(s)
    Year : 2003
    Mileage : 140000
    have you scnannned the car? if you haven't than this is a geussing game... it could well be a problem with one of the flaps not working, it could also be that the system is leaking... all in all the best solution woul be to scan the car... find the faultcode and take it from there. I wasn't aare that the system was previously re-gased as i didn't really read the first post i scanned it quickly... but ith the extra info you gave in your previous reply it does point to the circulation directional flaps... but a scan will point it out. Make sure you use a program/scanner that is for your opel as it might not have the option for scanning the reset of the systems on the canbus network so opcom or tech2/MDI/ dedicated opel OBD2 scanner will be needed.
  6. Thanks opel_estate thanked for this post
  7. #5
    May 2008
    Sweden
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 95000
    thanks mate,
    i might be able to borrow a CR Pro from Icarsoft not expecting too much as it is a "all cars supported" kind of tool, not opel/vx specific.
  8. #6
    Apr 2016
    Ipswich
    93 Post(s)
    Year : 2003
    Mileage : 140000
    Quote Originally Posted by opel_estate View Post
    thanks mate,
    If it doesn't find a place/ person with opel specific software to scan the car.
  9. #7
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    did u check the temperature flaps?
  1. climate control to dual climate control question
    By dougie89 in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2014, 19:25
  2. climate control
    By stu_c in forum Bodywork & Interior
    Last Post: 5th January 2011, 12:34
  3. Climate Control
    By liphook in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 04:10
  4. Climate Control
    By shark and mel in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 18:33
  5. Climate Control - Yes You Can Help!!!
    By mushy2007 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2007, 00:15
