Thanks Thanks:  3
Likes Likes:  1
Thread: Handbrake adjustment position
    Oct 2010
    N. Ireland
    Default Handbrake adjustment position
    Untitled.jpg What position does the little black plastic adjustment part need to be in, under normal operation? Most photos i see the part in fully forward, but some youtube videos suggest to have it fully back. What does it actually do?
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    it removes the slack on the handbrake cable... now the thing is auto adjusting so when you need to work on the handbrakes when you loosen it it should jump forward... to get the tension back you move it back this should tension the spring. and limit the travel of the handbrake lever... aka when tensioned up it should be a feww mm of the back. (this is with the lever down) took me a while to figure it out too so nothing wrong with you asking. when i adjusted mine it would be 3 clicks and it would hold the car leaving enough room to pull it up to 5 clicks to make it hard to put down. I preferred it that way.. others have a bit more play on it but if it travels past 6 clicks most MOT testers will say there is to much travel on the lever.
  3. Thanks melvin thanked for this post
  4. #3
    Oct 2010
    N. Ireland
    Thanks, my rear brake pads are well wore too. If i fit new pads will this help lessen travel on handbrake lever too? The hand brake lever goes up about 7 clicks at the minute, a bit too much.
  5. #4
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    It doesn't help, at least my lever clicks the same with new pads
  6. Thanks melvin thanked for this post
  7. #5
    Oct 2010
    N. Ireland
    Quote Originally Posted by horaa View Post
    Did you ever try adjusting at the handbrake?
  8. #6
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    At the lever or at the brake caliper? On the caliper is self adjusting.Try this, maybe it works but be careful on how much you tighten it https://www.youtube.com/watch?v=UMzpQUs1WOM
  9. #7
    Oct 2010
    N. Ireland
    Thanks, I seen this youtube video but not sure if i understand what the guy is actually doing there. I cant seem to translate the language. But it looks like he pulls handbrake lever up, holds the cable with pliers, then drop the lever a nick while holding the cable?
  10. #8
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    He pulls the handbrake, climps the mushroom on the right side with pliers, let's it down slowly multiple times untill it reaches fewer click(from 12 to 7) then he proceeds to tighten the whole thingie with the rear 2 screws(allen key and don't over tighthen them as it will jam the wheel). What i also recommend is after you have done jack the rear, pull the lever a few times, then release it and see if the wheel is spinning freely
    good luck if that doesn't work you will need rear calipers
  11. Thanks melvin thanked for this post
    Likes melvin liked this post
  1. Handbrake adjustment ask...
    By nikroc in forum Suspension, Wheels & Brakes
    Last Post: 16th April 2020, 23:27
  2. Handbrake adjustment
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2012, 19:40
  3. handbrake adjustment???
    By craigleeds in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2011, 03:43
  4. Handbrake adjustment
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 16:20
  5. 1.8 sxi handbrake adjustment
    By Paul4274 in forum Suspension, Wheels & Brakes
    Last Post: 12th June 2009, 16:26
