Thanks Thanks:  2
Thread: Front caliper size
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    Default Front caliper size
    Got a sticking n/s front brake ..might be caliper .If it is i have priced up a new caliper and brake hose .seller said needed to know brake disc size as there is 2 different caliper sizes.Looking on here it says 285mm for 1.8 petrol z18xer front discs.so would i need caliper that is also 285mm for front.cheers.p.s still waiting to get rear brake pipe sorted that has gone as well
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    if you tell them the disk size 285mm, they should know they need to send you the smaller caliper....But you are better off making sure by puling a wheel off and measuring the disk, some cars have been fitted with the bigger brake calipers and disks by the owners
  3. Thanks automan thanked for this post
  4. #3
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    Thanks i put 285mm discs on them .Do you know the size of the end fittings used on the brake pipes ?cheers
  5. #4
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    Nope I don't
  6. #5
    Regular Member JagRigger's Avatar
    Norfolk
    15 Post(s)
    Engine : 1.8 VVT ( No2 ! )
    Mileage : ... 299 k
    My 2007 Z18XER has 57mm ATE Callipers
  7. Thanks automan thanked for this post
  8. #6
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    Just go full mode, 347
  1. rear caliper size help please.
    By jamie64 in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2019, 09:10
  2. Identifying rear caliper size\type.
    By mick.n in forum Suspension, Wheels & Brakes
    Last Post: 6th March 2014, 20:31
  3. Rear Caliper Banjo bolt size?
    By Das in forum Suspension, Wheels & Brakes
    Last Post: 10th May 2013, 12:36
  4. caliper piston size
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2012, 22:39
  5. Torx size for brake caliper
    By ninja2111 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2008, 20:15
