Thread: Temperature gauge oddity
    Nov 2013
    suffolk
    Vehicle : vectra 2007
    Trim : sri
    Engine : z18xer
    Default Temperature gauge oddity
    Once old Veccy gets going, the gauge normally gets to 90deg - & stays there, but on a run today, I noticed around 15 miles down the road (it had been on 90deg) - it had dropped to about 70 - it stayed there until I could pull into a layby - I stopped the engine & had a look under the bonnet - everything looked & smelt! normal - coolant level OK etc (For a Vectra!) Restarted engine & it went straight to 90deg - & has been there ever since.
    Any answers?
    Apr 2022
    romania
    5 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    It's a opel, hiccups are normal. You know, just pretend you are at a doc and he says monitor the issue.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    you might want to take off the connector on the cluster, clean it and put it back. It should sort it out.
    Nov 2013
    suffolk
    Trim : sri
    Engine : z18xer
    Quote Originally Posted by northpole View Post
    If it does it again, I'll try a new temp sensor (easier to get at) I guess the instrument cluster connector, will be a beast to get at? But many thanks for your reply.
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    No it's easy I suggest you look it up
  1. Temperature gauge
    By any-mgzt in forum Engine & Drivetrain
    Last Post: 8th December 2012, 23:33
  2. temperature gauge
    By rfc52 in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2012, 15:20
  3. Temperature gauge
    By ziggy1 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd November 2012, 02:35
  4. temperature gauge
    By kewley in forum Engine & Drivetrain
    Last Post: 16th July 2011, 16:06
