Thread: Water in spare wheel well
    Regular Member Sam's Avatar
    May 2007
    Cambridgeshire
    Default Water in spare wheel well
    Once a month or so i have to dry out the spare wheel well as it's swimming in water. Anyone else had the same problem and found a cure???
    Any help appreciated!
    Regular Member dazzer t's Avatar
    stoke on trent
    someone else had the same problem the other day on here think they found aloose rubber grommet in the boot.
    Regular Member kgsric's Avatar
    Northants
    i noticed that in mine to the other day
    [Ex]Admin Duncan's Avatar
    Check the rubber seal around the rear lights - that can be a culprit. If you've had the lights off for any reason lately then that could be a prime candidate.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quarter glass is another good one and seal around Ariel has also been a culprit, water runs down the wire and into boot.
    it can also leak in via a poorley sealed on rear lip spolier, they may not have used enough sealant in the factory..
    we had a fishpond in the back of the CDTi, and one 'hosepipe' test later with an apprentice sat in the boot had him shouting and pointing into the de-trimmed hatch, it was flooding in the mounting holes..removed and resealed with silkaflex
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    When I got my SRi the spare wheel well was pretty wet too & IIRC in the last posting the finger was pointed at the aerial seal
    May 2007
    Cambridgeshire
    Thankyou people, i shall investigate!
    Sanquhar S/W Scotland
    Just found the same thing in mine,1st time thought I hadn't shut tailgate properly checked again today and its soaked again!
    Checked my rear light cluster and there was no seal on the left hand side! Dealer quoted £76 for new one,comes attatched to a new lamp unit!Cut a piece of rubber to size,silicon sealant round edges,job done!
  1. Water in spare wheel well after aerial repair
    By coooky in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 21:54
  2. Water in spare wheel well!
    By andyrad29 in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2012, 20:22
  3. water in spare wheel well
    By surfage in forum Vectra C / Signum Troubleshooting
    Last Post: 15th October 2012, 12:13
  4. Water in trunk and spare wheel getting rusty
    By matt89 in forum Bodywork & Interior
    Last Post: 26th August 2012, 09:55
  5. Signum - Water In Spare Wheel Well
    By Signatum in forum Bodywork & Interior
    Last Post: 23rd October 2008, 07:22
