Thread: Why is the diesel heavy still?
    ohrid
    Default Why is the diesel heavy still?
    I read the review of the new Nisan Qashqai
    1,6i / 2,0i / 1,5dci / 2,0dci
    1392/1437 /1471 / 1590 kg
    2,0 diesel is 150kg heavier than 2,0 petrol.
    Why is the diesel still so heavy and when can we expect for it to slim down.
    The performance of the diesel today is great, but they can be even superior if we can chop off 200 kg.
    BTW this nissan is expected to be a HIT, and a direct competitor to the Golf.
    May 2007
    south ockendon
    something to do with deisel engines still being made with a cast iron block maybe
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Diesel engine have to be made far more robustly than petrols, as the compression ratios, and peak cylinder pressures are far higher. So they weight far more.
    ohrid
    the D4D toyota is made of aluminium all the way....
    The Isuzu Y30 in the Vectra 3.0 V6 CDTI is also aluminium, reducing the weight
    One disadvantage is they do not like heat and warped cylinder heads can become an issue at high mileage
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I thought the Vectra had a cast iron block & aluminium cylinder head!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Refer to my previous comment, it is true for whatever material is used
    Mar 2007
    GB
    Also, aren't youe comparing the turbo-diesel car's weight to normally aspirated petrol engined ones? I think you'll find that having a turbo on any car adds maybe 50kg or so.
    Mar 2007
    GB
    Was just looking on the "Vauxhall Product Forum", current car weights: -
    Hatchback 2.0i Turbo 16v SRi - 1456kg
    Hatchback 1.9 CDTi 16v (150) SRi - 1456kg
    i.e., the same for the current models of exactly the same trim.
    When comparing weights, the level of trim matters a fair bit.
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. Diesel Smell when stationary (after heavy driving)
    By Flek in forum Engine & Drivetrain
    Last Post: 28th November 2009, 17:42
  3. BP Ultimate Diesel vs Morrison's mucky Diesel
    By Big Knox in forum General Chat
    Last Post: 31st March 2009, 13:11
  4. Shell Diesel Extra Or BP Ultimax Diesel
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 13:25
  5. How Heavy is Diesel
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2006, 21:24
