Results 1 to 10 of 19
Thread: Cruise Control
    SCOTLAND
    Default Cruise Control
    Does cruise control increase or decrease mpg, heard different views so does anyone out there know for definite whether it is more economical or not?????
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    depends on how you would drive personally anyway. So could do either or both, or neither.
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Have had cruise on a Veecy 2.2 and now on the 2.0t Siggy and can get 3-4 mpg better not using it - again though it's down to how you use the right foot
    Regular Member Vec-6289's Avatar
    May 2007
    Cirencester (Days off) Lyneham (Work days)
    With me i prob get more when i use it (on motorways and long dual carriageways) as i tend to vary my speed quite alot when i'm not using it, but when i am i tend not to be bothered. Also stops me speeding as much, which has to be good!
    Regular Member surreyl31's Avatar
    Feb 2007
    somerset
    its about the same with mine on the mpg
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    I've often wondered this too, I get the impression the mpg is slightly less when I put it on, but could be imagining it.
    Does anyone know how the cruise manages to keep the speed constant when you go down a very steep hill in a high gear? Amazes me that does, and does that use extra fuel in itself, when it struggles to slow the car down?
    Nicking Ya Dinner.
    Quote Originally Posted by Ste View Post
    In one, a driver will be heavier or lighter on the throttle, the CC will just work to the speed it's told to, so you could be slightly on the gas a bit more than the CC so you will get less, however it works the other way also, I think personally there isn't much in it either side.
    Melbourne, Australia
    Quote Originally Posted by Hideous View Post
    Provided the engine has warmed up, it cuts the fuel off. The same thing will happen if you have cruise control off and have your foot off the accelerator.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    if the hill is so steep that even 0 throttle will cause the vehicle speed to rise (ie motoring) then is will not keep the same speed. It will only keep constant speed if it can by engine braking alone, ie it cannot apply the brakes.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    yeah, i know it's not connected to the brakes.
    I have noticed it speeds up slightly when going steeply downhill, but have been surprised how it has stayed pretty close to my cruise speed.
    hmmm... it must be just the engine, yes.
    It feels different to petrol engined cars i've had with cruise control...
    edit: shouldn't be though, just done some Googling, and apparantly, diesels are WORSE for engine braking than petrols!
    Just my imagination then, forget it.
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
