Thread: SCV/Rail Pressure Sensor
    Jan 2023
    Stoke On Trent
    Engine : 3.0
    Default SCV/Rail Pressure Sensor
    Hi all, hope you are well.
    Z30DT has got SCV symptoms - Juddering under acceleration. P0093-52 error code has come up Rail Pressure Range/Performance. I've been advised to try the sensor first before going for SCV's. I'm having trouble getting hold of one though so I'm having to go for a dreaded eBay part. Can anyone here confirm if this is the sensor or could point me in the direction of a listing with the correct sensor.
    https://www.ebay.co.uk/itm/153178617...mis&media=COPY
    I already have the SCV's waiting to go on if this doesn't work.
    Jan 2023
    Stoke On Trent
    Engine : 3.0
    And also, I've seen on here somewhere (I think - I can't find the post now to link) that one way to test it is the sensor causing the issues is to drive the car without the sensor on. It will be rough but if it is the cause of the intermittent power issues then they will go away. Is this correct?
    Jan 2023
    Stoke On Trent
    Engine : 3.0
    Ok, I've managed get my brother (my mechanic lol) to get the sensor off. It's a Denso 6160. My question now is can I buy any denso 6160 rail pressure sensor off eBay or does it need to be a 6160 but for the Z30DT specifically.
    Jan 2023
    Stoke On Trent
    Engine : 3.0
    Never mind, sorted. EGR issues now/as well
    Dec 2021
    Kaiserslautern
    Trim : Cdti
    Engine : 3.0
    Did your brother find the Sensor? I haven't been able to get my hands on one. Calling Opel tomorrow, but still hopeful of a more reasonable option.
    Did the sensor fix your issue? What's going on with the EGR? Do you have a code?
  1. Z19dth fuel rail pressure sensor
    By neill in forum Engine & Drivetrain
    Last Post: 12th April 2023, 22:10
  2. Problem with fuel rail pressure sensor
    By RuP3r in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2021, 17:01
  3. plug for rail pressure sensor.
    By fencehouses in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2014, 10:51
  4. Fuel Rail Pressure Sensor - another thread
    By Stevo2 in forum Engine & Drivetrain
    Last Post: 30th June 2010, 20:52
  5. Fuel Rail Pressure sensor
    By RobW in forum Engine & Drivetrain
    Last Post: 3rd December 2009, 16:55
