Hello, the yellow tire pressure light has come on on my vectra c. Pressure not present on 3 wheels, after 1 hour spent on the hole everything reappeared regularly. What's the matter.
Thank you
Thank you
Hello go and introduce yourself in the appropriate section on the forum and don't forget to put up a picture of the car..
To guide you a bit: Either sensors on the wheels have come off or sensor inside the wheelarches that pick up the signal have a problem (could be cable related) either way a scan will tell you what is wrong and the DTC will guide you towards the solution.
And with owning a Vectra it's the best thing to make sure you have your own Opel specific diagnostic tool. Otherwise it can get very expensive having the car scanned at a garage because you'll get more warnings on the screen than you'd expect. And some don't even show up on the screen they'll illuminate the workshop light (car with a spanner through it).
Thanks for the reply.
I had the yellow tire light on and not the wrench
can you tell me how the sensor cable is made for the station wagon model? does the cable come from the front sensors go to the rear ones and then enter the ecu? where can i find the tpms sensor unit in the rear compartment? I believe there is some contact in one of the connecters.
thank you
regardless opcom/tech2 will tell you what is wrong.. without it you'll just be checking the whole system, so it's worth to scan the car. that said i don't know as my car doesn't have TPMS, and with all the problems with the sensors and wiring i'm glad it doesn't have it.
