Thanks Thanks:  9
Results 1 to 10 of 24
Thread: Hot start/stalling problem
    May 2013
    Aberdeen
    Trim : Civic
    Engine : 1800cc
    Year : 2002
    Default Hot start/stalling problem
    Car (ZX18E) went through a week or so of starting when cold but, once warmed up, would not start again. Now, post fuel filter and crankshaft sensor change, the car either won’t start, or will start but then stall after about fifteen minutes (95% of the time it just won’t start).
    No EML, no codes (but the lightbulb symbol is flashing).
    The annoying thing is that I thought the crankshaft sensor change had cured the problem as, immediately afterwards, it started straight away, ran for 40 minutes, and then restarted easily.
    Any ideas?
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Suggest you get Admin to put this in Vectra section as this is Insignia section and they don't use this engine.
    What code reader are you using? Really need Opcom or Tech2.
  3. Thanks PaulFraser thanked for this post
  4. #3
    May 2013
    Aberdeen
    Trim : Civic
    Engine : 1800cc
    Year : 2002
    Thanks, my bad—I’ll ask the admins to move it.
    ELM127/bluetooth reader, but I’ve ordered a Opcom off of Ebay. What should I be looking at on that?
  5. #4
    Dec 2010
    London
    8 Post(s)
    Trim : Premium SE
    Quote Originally Posted by PaulFraser View Post
    Not allowed to say too much on here about Opcom as it's cloned software but if any codes are present then they will show.
    You can let us know the fault codes and check RPM as this is Crankshaft signal. @plasma can you move this to Vectra please.
  6. Thanks PaulFraser thanked for this post
  7. #5
    Administrator plasma's Avatar
    On the Forum
    564 Post(s)
    Engine : 150
    Mileage : 74000
    @plasma has moved it and its fine to talk about the results of opcom readouts just not where to purchaes it or for help installing it... (info for @PaulFraser )
  8. Thanks troutybrown, PaulFraser thanked for this post
  9. #6
    May 2013
    Aberdeen
    Trim : Civic
    Engine : 1800cc
    Year : 2002
    Quote Originally Posted by plasma View Post
    Noted, thank you.
  10. #7
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    88 Post(s)
    Vehicle : Vectra C Saloon
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    if you got an andriod phone use scanmyopelcan (you can download it from the google playstore and scan it for free) it will work with the elm327bt dongle I got it myself for on the go but i paid for it as the free version doesn't allow you to remove the faultcodes. It's not as good as tech2/GDS or opcom for that matter but it tells you what is wrong with the Engine, CIM, ABS or Auto gearbox and it can log live data.. on the newer cars (insignia etc) it can access more modules... but no programming, adding keys etc can be done with it... it's pure diagnostics only.
  11. Thanks PaulFraser thanked for this post
  12. #8
    Nov 2013
    suffolk
    Vehicle : vectra 2007
    Trim : sri
    Engine : z18xer
    Any ideas?
    This sort of problem, is often the Temperature sensor - usually mounted on the thermostat housing.
  13. Thanks PaulFraser thanked for this post
  14. #9
    May 2013
    Aberdeen
    Trim : Civic
    Engine : 1800cc
    Year : 2002
    Finally got the Op-com reader working. Any suggestions where to go from here? (Beavor-bob—I assume that a normal coolant temperature reading after sitting for several hours would mean that isn’t what is the problem is?)
    PS Thanks for your comment, northpole.
  15. #10
    Dec 2010
    London
    8 Post(s)
    Trim : Premium SE
    Do a scan for any fault codes also look at live data for rpm signal when turning engine over.
  1. first start problem
    By tonci26 in forum Engine & Drivetrain
    Last Post: 7th September 2014, 18:45
  2. Vectra 1.9CDTi 120 stalling problem - I NEED ANSWERS!!
    By neo196910 in forum Engine & Drivetrain
    Last Post: 26th November 2013, 16:17
  3. Vectra C wont start after stalling
    By Joshuashaw in forum Vectra C / Signum Troubleshooting
    Last Post: 15th January 2013, 00:19
  4. Vectra C 3.2 GSi stalling problem
    By DannyVecCGSi in forum Engine & Drivetrain
    Last Post: 10th December 2010, 16:30
  5. Problem with my sri 1.8 on start up
    By FireBrad in forum Engine & Drivetrain
    Last Post: 26th May 2010, 15:41
