Thread: Gearbox Disaster
    May 2007
    Ilford
    Default Gearbox Disaster
    Hello - I own Signum Elite 2.2. Auto 2003 67 k out of warranty
    Huge problem - about 2 months ago going up M1 dreaded car and spanner appeared and gearbox was stuck in 2nd and 5th. Took it into Vauxhall who scanned it with code P0715. They said it would cost £250 to find out what the problem was but suspected water in gearbox. Being a bit short of money I decided to get a reconditioned one after they told me there had been water in gearbox once
    After £1300 eveything seemed fine until yesterday when original fault appeared.
    My prefered next move is to take car back to Vauxhall get fault properly diagnosed and try to get it sorted out as good will out of warranty repair (car has always been serviced at main dealers) I will then try to get my £1300 back through small claims court as I suspect the recon place just conned me
    Question is has anyone ever had this fault before - I am hoping it is not actually a serious gearbox problem because although I can sue the recon place it is a lot of hastle and perhaps it is some minor electrical problem?
    Jul 2006
    Mexico
    As far as I know water in the gear box is kind of a known problem. I´m not shure if most of vectras suffer it or just the early ones.
    Oct 2006
    Wellingborough
    Quick google on your code
    "P0715 Input/Turbine Speed Sensor Circuit "
    If that helps at all?
    Feb 2006
    Guttedsville
    It's a well known problem, Mark (GSi 3.2) knows all about this, as do Vauxhall!
    There's a radiator that cools the gearbox oil, basically a seal in this goes, lets the water and gearbox oil mix and that's basically the end of it.
    Probably not quite right, but probably close enough.
    Regular Member Islander's Avatar
    Barrow-in-Furness
    Quote Originally Posted by Andrew's SRi View Post
    Yep, had a similar problem with my 2.5 TD Omega, because the engine coolant is under positive pressure when the seal blows the coolant is forced into the 'box blowing the transmission fluid out, then because the clutch plates are bonded using water soluble glue over time they disintegrate hey presto! one knackered 'box
  1. I hit a disaster
    Last Post: 30th December 2012, 19:31
  2. Disaster!
    By bbdp in forum Bodywork & Interior
    Last Post: 21st March 2012, 17:34
  3. Sat Nav disaster!
    By MusicalDave in forum Insignia Chat (READ ONLY)
    Last Post: 6th December 2010, 14:58
  4. Disaster today
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2009, 22:10
  5. D Day might be disaster day :(
    By soulman in forum The 'Off Topic' room
    Last Post: 18th April 2009, 10:26
