Thanks Thanks:  1
Likes Likes:  6
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Hello from Denmark
  1. #11
    Apr 2016
    Good man for eradicating the orange bulbs... I do it to each and every car I own and if they have orange indicator lenses I remove the lenses for clear ones and silver vision bulbs... it just looks better.
  2. #12
    New Member H3nrik V!'s Avatar
    Apr 2023
    Naestved
    Vehicle : Vectra C
    Trim : OPC (VXR) Line II
    Engine : Z20NET
    Year : 2008
    Quote Originally Posted by northpole10 View Post
    Absolutely a sure part of my car budget. At the moment I'm gathering patience to remove air filter box and window washer filler tube so I can get to the front ones. Or ... Can the headlights be removed without removing the bumper?
  3. #13
    Apr 2023
    Naestved
    Vehicle : Vectra C
    Engine : Z20NET
    Year : 2008
  4. #14
    Apr 2016
    Only if you got really small hands... I don't so I remove the bumper it doesn't take that long and you don't really have to remove the bottom plate that connects to the subframe as it gives you enough room to undo the bottom bolts on the headlights... than you can loosen the top ones move the headlights forward and you can put the bulbs in.. sorted
  5. #15
    Apr 2023
    Naestved
    Vehicle : Vectra C
    Engine : Z20NET
    Year : 2008
    So, you don't remove the bumper totally, just loosen it in the top, to get enough room to unscrew the headlights?
  6. #16
    Apr 2016
    Yes but you'll have to remove the screws in the wheel arches and the ones around the grille and middle section of the bumper.. pop out the sides and slide it back a bit... it should give you enough room to remove the headlights. Vumper is plastic so it can bend without causing damage to the paint or the shape of the bumper
  1. Greetings from Denmark
    By KristianK in forum Introduce yourself.
    Last Post: 11th November 2014, 07:22
  2. Hello from Denmark :)
    By Blomstrand in forum Introduce yourself.
    Last Post: 11th February 2014, 08:15
  3. New in here.... From Denmark
    By Jesperchr in forum Introduce yourself.
    Last Post: 13th May 2012, 08:46
  4. Hello from Denmark
    By dnial in forum Introduce yourself.
    Last Post: 28th April 2012, 17:25
  5. Hello from Denmark...
    By Dalle1985 in forum Introduce yourself.
    Last Post: 3rd April 2012, 16:27
