Thanks Thanks:  9
Likes Likes:  9
Results 1 to 10 of 25
Thread: Ignition issue/fuel pump issue?
    Jul 2012
    N.Ireland
    Vehicle : Vectra C 1.9CDTi
    Trim : Club
    Engine : ZDT?
    Year : '05
    Mileage : 214k
    Default Ignition issue/fuel pump issue?
    Recently my Vectra C 1.9cdti 8v has begun being picky as to when it wants to start. Sometimes I turn on the ignition and the TCS light will stay on leaving me unable to start the car - I turn key the last bit to crank engine and nothing happens.
    I could repeat the procedure another time and the TCS light will go out and car will start or I might have to repeat it 5, 10 times before the light will go out.
    What I have noticed is that the fuel pump seems to be involved in this issue. If I turn the ignition on and don't hear the whirr of the fuel pump then I know the TCS light will stay on and I'm not getting the car to start. If I turn the ignition on/off until I hear the fuel pump then the TCS light will go off and everything is fine.
    Any ideas?
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    26 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Get codes read buy the un named one preferably. Ad it get to parts other drinks can’t get….
    ​​​VECTRA VXRs BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2023 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
  3. Thanks Liamalone thanked for this post
  4. #3
    Jul 2012
    N.Ireland
    Trim : Club
    Engine : ZDT?
    Year : '05
    Mileage : 214k
    U2105-00 CAN-Bus No Communication with ECM (Engine Control Module) U2105-00 <Unknown DTC>
    U2105-00 CAN-Bus no Communication with ECM (Engine Control Module)
    U2105-71 CAN-Bus ECM Message Range/Performance
    U2105-7F CAN-Bus No Communication with ECM (Engine Control Module)
    B2966-05 Driver Doorknob Circuit Open or High Voltage
    U2139-71 <Unknown DTC>
    B2460-04 <Unknown DTC>
    Cleared what it cleared and left with this:
    B2966-05 Driver Doorknob Circuit Open or High Voltage B2460-04 <Unknown DTC>
  5. #4
    Sep 2015
    Norwich
    26 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Yes clear codes I do it to see what comes back. When your symptoms happen again reread as from what you have there is…from what see uec not reading ecu so ecu fault uec fault or bad connection then going up the line depending on pre/face lift the abs plug fault.
  6. Thanks Liamalone thanked for this post
  7. #5
    Jul 2012
    N.Ireland
    Trim : Club
    Engine : ZDT?
    Year : '05
    Mileage : 214k
    Thanks, fyi it's an '05 pre facelift.
    I went out and cleared all codes and then recreated the issue and below are the fault codes from a fresh read:
    Any help? Thanks
  8. #6
    Sep 2015
    Norwich
    26 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    The last 2 you can most likely forget. The other 3 from uec to ecu if more units saying no coms to ecu I would put that at fault but only uec. So check fuses bcm and uec clean them or replace, remove uec and clean contacts underneath, also clean abs plug and there is another just behind clean that as well.
  9. Thanks Liamalone thanked for this post
    Likes Liamalone liked this post
  10. #7
    Jul 2012
    N.Ireland
    Trim : Club
    Engine : ZDT?
    Year : '05
    Mileage : 214k
    Thanks Jon, much appreciated You couldn't elaborate on the abbreviations at all please, You've lost me on most of that bar and tbh lol sorry
  11. #8
    Sep 2015
    Norwich
    26 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Uec..is the fuse box in engine bay check fuses and unbolt and check clean contacts underneath. Bcm fuse box passenger side behind cover when door is open check fuses clean contacts. As pre face abs unit known fault for wiring on plug the unit top right engine bay remove plug clean contacts. Just behind that another plug same with that. In some cases replacing fuses does cure problems. Also check earth points. After that would try replacing uec like for like or upgrade not downgrade.
  12. Thanks Liamalone thanked for this post
    Likes Liamalone, bibu16v liked this post
  13. #9
    Jul 2012
    N.Ireland
    Trim : Club
    Engine : ZDT?
    Year : '05
    Mileage : 214k
    That's more my level of understanding lol. Thankyou kindly, I really appreciate that. I'll keep you posted on how I get on!
  14. Likes bibu16v liked this post
  15. #10
    Jul 2012
    N.Ireland
    Trim : Club
    Engine : ZDT?
    Year : '05
    Mileage : 214k
    Finally got around to actioning this, no joy unfortunately
    Cleaned fuses in engine bay, connection beneath fuse box and the two plugs, no change.
    Found I had water in spare wheel bay, been there a while it seemed. Put two and two together and with the timeline matching up possibly, I cleaned the fuses in the boot. No joy. Rear window heater not working now though. Changed majority of fuses in there apart from a couple of 5A ones as motor factors had none, also sprayed contact cleaner on the connections of the various plugs beside that fuse box. No joy.
    Cleaned fuses inside passenger door, no joy.
    Semi cleaned an earth point, I think, below the front of battery box, it was particularly ’powdery' ... could only loosen the nut a bit and toothbrush it for fear of not getting it back on/losing it, I only have a basic socket set. No difference.
    Scanned codes again with ignition on:
    B3700-0F Wiper Interval Circuit Malfunction
    B3794-08 Switch Cruise Control Circuit Malfunction
    U2105-7F CAN-Bus No Communication with ECM (Engine Control Module) U2113-00 CAN-Bus No Communication with SDM (Sensing & Diagnostic Module, Airbag) -
    B3901-00 Wrong Environment Identifier Received
    B3011-05 Trunk Switch Circuit Open or High Voltage
    B0283-06 Rear Window Heater Low Voltage or Circuit Open B3596-00 Invalid Trouble Code Please Ignore!
    B1325-03 System Voltage Low Voltage
    Cleared them and scanned again with engine running:
    Did I read somewhere that abs plugs/wiring behind each front wheel would be worth looking at?
  1. high pressure fuel pump issue Z19dth 150
    By cselite in forum Engine & Drivetrain
    Last Post: 14th June 2021, 00:14
  2. Fuel pump issue?
    By Phenoxan in forum Engine & Drivetrain
    Last Post: 3rd July 2016, 18:32
  3. Replies: 3
    Last Post: 21st July 2012, 22:02
  4. 2.2Dti Fuel Pump issue's?
    By sigtim in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 21:48
  5. 3.0 Dti fuel pump issue
    By Agoogy in forum Engine & Drivetrain
    Last Post: 20th May 2010, 10:51
